Three issues to look into
Removing Triumph sludge tube
by reverb - 05/08/23 7:30 pm
Peter R
Peter R
Lannis 91
DavidP 75
Allan G 67
Lannis 44
Cyborg 23
raf940 22
12,520 Registered Users
Topics77,075
Posts792,682
Members12,520
OP Online Content
A thread on the Gold Star Forum sent me to the "BSA" drawer of my tool chest. The factory supplied plenty of special service tools, but not all of them are available anymore, and not all jobs were covered by a special tool. Because of this, over the past ~40 years I've fabricated tools of my own to make some of these jobs easier. I know many others have done this as well, so by all means please add to this thread.
Many years ago I discovered I had tools that I had made but that I no longer remembered what they were for. So, I started writing their function on them as I made them. Unfortunately, in a few cases the paint has worn off, and in a few other cases my notation wasn't sufficiently detailed. All I know about a few tools is they are in my BSA drawer, so I probably made them for either an M21, Gold Star, or A10. However, since BSA's pre-unit singles and twins shared so much technology, there's a pretty good chance a tool I made for my M21 also performs the same function on another BSA model.
Using a socket to tighten and loosen a nut is so much nicer (and easier) than whacking it with a hammer, so the following is a socket for the shock absorber on the mainshaft.
If the spring is a bit too long to allow you to get the shock absorber nut started, compressing it a vise and using the following "C" clamps to hold it solves the problem. The clamps are made of 1/4" steel, the top and bottom of the "C" are 1/4" high, the side is 3/8", with the space between the top and bottom 1-1/8" (i.e. the compressed length of the spring is 1-1/8"). The spring is placed partway into a vise, compressed, the clamps slipped on, and the vise opened up. At this point the compressed spring is storing a lot of energy so you definitely don't want to bump the clamps while slipping the assembly together and tightening the nut.
Like the cush drive, removing the Gearbox sprocket nut cries out for a sprag socket. I made the following from a 3/4"-drive 1-1/2" socket onto which I brazed a 1/2"-drive 15/16" socket. The OD of the gearbox shaft is small enough to fit through the 3/4" hole in the first socket and into the second.
I don't remember anythng about the following tool, but what I have written on it is "M21 cam pinion post extractor (61-691)". It has a 1" ID and is 2.6" deep.
I don't remember anything about the following, but it's 1-1/2" x 24tpi and I wrote on it "Head race removal."
A Gold star has a steering stem nut with 6 notches in it. The elegant way of tightening it is with the following socket:
The following are laps for the seat in AMAL GP float bowl. The OD of the ends that fit into the float bowl are 0.275". The larger OD at the end is what you use to twirl them between your fingers.
This is a very common tool, made by bolting together a driven and a driving clutch plate, along with an arm to hold it from moving. I made this when I got my first A10 ~40 years ago so it's pretty crude. But, it works fine, so I continue to use it.
The slots on the screws covering the clutch adjuster are pretty chewed up on many bikes because the owners don't have a screwdriver of the correct width. Also, they typically are tightened by using a hammer on a screwdriver held at an angle, which isn't the greatest way of giving them the correct torque (or keeping them looking new). Somewhere I have a "screwdriver" I made from a 1/4"-drive socket and a bar of brass of the same width and length of the slot, but I couldn't find it today. Instead, the photo is of a commercial screwdriver bit that has the correct width, that I also use.
Author: The Gold Star Buyer's Companion
Author: The Ariel Chronicles
Co-Curator and Co-Author: The Motorcycle: Design, Art, Desire
Co-Curator and Chapter Author: The Art of the Motorcycle
Editor: Motorcycling at the Turn of the Century
Nice! I wish you were my neighbour wink
Very nice!
Slips over the pinions with enough end space to then use a bolt into the pinion to make a puller. Beats foraging around for a socket or box spanner and penny washers to do the job blush blush
Bernie
'81 T140
'66 A50CC project
'56 SQ4 restored
'49 and '56 M21s
'62 99 Dommie
S8 project
G80 project
OP Online Content
Thanks to everyone for the nice comments and helpful identifications.
Originally Posted by Trevor
I have noticed some (if not all original BSA) outer steering bearing cups have a thread in them. This tool probably screws into that.
Ah, very likely so.
You're right. I looked it up after I read your email. I got my M21 over 35 years ago and rebuilt the engine then, so I haven't used that tool for a very long time. This is one of the reasons I started using a paint pen to write identifying information on such tools.
I had thought my post of these special tools had slipped by unnoticed, or was of no interest. I turned up a few more since I wrote that post, so will take photos and upload them later today or tomorrow. Meanwhile, by all means add to this gallery of BSA special tools.
OP Online Content
I found three more special tools I made for pre-unit BSAs, and there may be a few more lurking in the garage.
The next photo shows two engine locking devices, with Matchless 750 cylinders standing in because they were easier to reach as well as lighter (at least individually, if not as a pair). If I need to keep the engine from rotating when the head is removed from the engine, pistons stop when they meet the 1" x 1/2" x 9" bar bolted diagonally across the cylinders. Rather than making holes specific to a given engine, the 3/8" x 8" slot in the middle makes this bar "universal."
The 8" rod in front of the cylinders goes through the small ends of the rods to lock the engine at times when both the head and cylinders are removed. I made three rods, with diameters of 0.67", 0.74", and 0.86", for a variety of engines. In each case the diameter is 0.01" smaller than the small ends for an easy slip fit.
The screw holding the field coil in the bottom of a Lucas dynamo can be a real headache to remove. This tool clamps the screwdriver bit in the screw so it can't pop out of the slot when breaking it loose. After it is loose the assembly is removed. The screwdriver has a 1/2" square drive and fits into a shallow recess machined into the top of the assembly. It is driven by a 3/8"-1/2" adapter that passes through a hole.
I can't bring myself to destroy good components so, even though I have a few extra gearboxes, I bought a Std gearbox shell that had a 3/4" x 2" weld in it. I marked all the places that could be removed without affecting anything, then spent a few hours with my mill turning it into Swiss cheese (you can't see all the machined openings in the photo, but every surface that can be removed, has been). This lets me ensure that all the clearances are just what they should be when I assemble a gearbox from mixed components (but, since I have it, I use it at all times), detents engage perfectly, etc..
