WTB - Triumph disc brake frame.
by J Rowe - 06/06/23 9:57 pm
by Morgan aka admin - 06/06/23 4:50 pm
Removing Triumph sludge tube
by reverb - 05/08/23 7:30 pm
Lannis 90
DavidP 79
Allan G 58
Lannis 41
Cyborg 24
Ossaphantom, Pokey, Geoff U, Michael Pelkey, Myrt
12,523 Registered Users
Topics77,101
Posts793,027
Members12,523
Page 2 of 2 1 2
raf940 #906827 04/06/23 12:06 pm
DOPE
DOPE
fords.
my 63 falcon had a plastic bag under the dash for washer fluid. you reached up with your foot and squished it to wash the windshield
watermelons, and turnips, and a contaminator
and other stuff
raf940 #906882 04/06/23 11:39 pm
Old VW Beetles used the spare tire to pressurize the windshield washer. If it quit working you needed to put air in the tire as it was at only 20psi.
Of course, that was back when air was free at your local gas station.
Keep your head up and your stick on the ice.
72 T150V "Wotan"
DavidP #906935 04/07/23 5:57 pm
Originally Posted by DavidP
Originally Posted by kevin
tony was a spectacular tuner. he worked that T140 with the nasty amal mk2 carbs forever until he decided to go with TM mikunis and fix it once and for all.
I worked on jetting my A65 with VMs forever. Put Mk2s on my Bonneville and forgot about them, only changed the idle jets and forgot about problems.
BTW I found a use for the electric start button on my Trident, I wired it to the horns. Now I have button for horns on either hand.
So... is the horn twice as loud if you press both at once, brother? laughing
Lesya Ukrainka:
“He who has not lived through a storm/does not know the price of strength.”
1 member likes this: BeezaBryan
DavidP #906936 04/07/23 6:00 pm
[i][/i][u][/u]
HA, right?. What's next, charging more for drinking water than gasoline? help
Lesya Ukrainka:
[i][/i][u][/u]
Yup, that'd be almost as unbelievable as charging more for 2-stroke oil than for decent bourbon....
I would rather have questions that can't be answered than answers that can't be questioned.
raf940 #906949 04/07/23 6:49 pm
A fifth of HP black printer ink is about $400
What we've got he'ah... is failure... to communicate.
whats it taste like ?
raf940 #906961 04/07/23 8:53 pm
Earth tones.
Hint of licorice.
1 member likes this: kevin
Earth tones.
Hint of licorice.
ahh , Palo Alto terroir
1 member likes this: Hugh Jörgen
quinten #906975 04/07/23 11:47 pm
Unprintable.
raf940 #906987 04/08/23 3:54 am
tried to taste it.......but got my tongue stuck in the printer!!!!
I'll let you know, they both feed the same relay. But with two Fiamm horns it's as loud as my K100. laugh
72 T150V "Wotan"
kevin #907017 04/08/23 2:33 pm
Re Tony's bike work. Kevin, you hit the nail on the head. Tony said he enjoyed building the bikes more than riding them. He Said he never rode more than 100 miles at a time. Some of his longest rides were with me in the Finger Lakes of New York.
Now the generation gap- I had a '62 American Motors Rambler. Had vacuum operated windshield wipers. The wipers would speed up and slow down depending on how fast the motor turned. Also had the windshield washer in a bag and had a push button transmission on the dashboard. I own Tony's Ducati. He got the carburetion perfect!
I had a '67 AMC Rebel that had the same vacuum operated wipers - AMC stuck with those primitive things until the end.
They didn't actually operate on how fast the motor turned - they were powered by the manifold vacuum. When vacuum was high (when the engine was idling or cruising or decelerating) the wipers would go like mad. When you pressed the accelerator, however, the wipers would come almost to a stop, and that's when they were working properly.
So when you were following a truck in the rain, with the wipers running at normal speed, and saw an opportunity to pass, and mashed the pedal to pull out into the truck's spray and roostertail, the wipers would STOP, and you were blind as a bat until you backed off. Can't believe they stayed with it.
raf940 #907037 04/08/23 7:25 pm
Don’t know about amc but ford had a combination fuel and vacuum pump to stop that problem with the wipers.
windy
72 combat
if it aint broke fix it till it is
switchbackcreek.com
DavidP #907048 04/08/23 11:16 pm
63 falcon
hahahahaha!
had 63 comet same deal. one could adjust the nozzles to squirt sideways.
people back then didn't know about washers. i would drive thru the strip mall and nail a couple of folks.
water only.
that set up worked great! just stomp! LMFAO!
always worked too.
raf940 #907051 04/08/23 11:40 pm
I smile when I think back about driving in the rain with the old vacuum wipers. Going uphill they would stop moving then almost fly off the wiper arms as you rolled downhill. Same thing when you accelerated from a stop and then backed off the accelerator to change gears. You had to understand and interact with all the mechanical components of your car. I'm sure that's part of the appeal of our old Brit bikes.
raf940 #907062 04/09/23 2:05 am
DOPE
DOPE
my old hudson was that way
10-inch wiper blades meant that it really didnt matter how fast they went, they were worthless all the time anyway
and other stuff
Page 2 of 2 1 2
