Topics77,101
Posts793,029
Members12,523
Most Online230 Mar 11th, 2023
Posts: 4,695 Likes: 240
Posts: 4,695 Likes: 240 |
my pal calvin's 72 A65T frame leaks like a sieve.....it has for a long time he patched crack with JB but that's kaput...here are a couple of questions....how much of bike needs to be taken apart to fix? crack seems to be on timing side at top engine mount bracket....can it be brazed? if has to be welded how much electrical stuff needs to be unhooked if any? thanks in advance for any help in this oily situation
1972 Triumph T120 1968 BSA A65 1968 MGB Roadster 1979 Chevrolet Camaro Berlinetta 1969 Honda Mini Trail 2004 Honda Shadow Aero 1949 Ferguson TE20 tractor 1975 yamaha xs650b 2 olive drab WWII military bicycle replicas
Posts: 10,878 Likes: 314
Posts: 10,878 Likes: 314 |
if has to be welded how much electrical stuff needs to be unhooked if any? . Any electronic ignition components especially the control box. The regulator regulator. Brazing requires that the surfaces to be welded absolutely from from any paint or oil!!!!![/quote] We ran a short story in Vintage Bike that came from one of the road testors that tested bikes when the factory was having frame problems with the oil in frame models. He claimed that he could break a frame in the swing arm area at will. They did get it better, but as you see the cure was not perfect The best repair I have seen is the one that Keith Martin (Big D Cycles, Dallas TX) did to all of his oil in frame race bikes. You should ask him if he brazed or welded the added triangulated support tubing. John
Allan G |
Posts: 5,605 Likes: 317
Posts: 5,605 Likes: 317 |
Once you have put any goo on the surface you severly reduce the cance of any real metal fix taking You usually get a etter repair with oxy ecause the oxy can burn off all of the trash which floats to the top of the weld puddle Down side is the relatively large HAZ will cause a change in the physical strength of the welded region and can cause the site to warp or bend during the repair or latter on in use . Even with a good weld you have to remember that it is in effect a casting between two pieces of wrought metal thus will have a substantially lower tensile strength so will need to be thicker by at least a factor of 2 plus it will be less flexiable than the surrounding tube
Bike Beesa Trevor
Posts: 262 Likes: 26
Posts: 262 Likes: 26 |
the hard part is cleaning the oil out of the cracks sometimes it is better to weld or braze a plate over the crack. that moves the repair away from the original damage. it is best to fit the contours pretty close to be effective. that repair might even work with epoxy. or... 3M 5400 poly glue. its made to glue sailboats together... amazing stuff. remove the elix if you like. I have welded many vehicles without removing anything. just keep the ground lead on bare metal close to the work. leave the battery in too
Posts: 6,230 Likes: 332
Posts: 6,230 Likes: 332 |
My 71 had a crack in the exact same place, it was fixed by removing the rear engine plates, draining the oil, Veeing out the crack and welding, . I firmly beleive this crack is created by un lubed swing arm bearings, at least mine had suffered this, I had to replace the bushes, bobbins and spindle and fit grease nipples which were missing. Do not braze, and remember glue doesnt work, welding does work.
Posts: 376 Likes: 11
Posts: 376 Likes: 11 |
Hi there, on my 71 Firebird I doubt the frame was oiltight right from the start/the assembly line. I had bought the good looking bike and it was always leaky. When looking at the issue I am inclined to think the bracket was not welded properly and the weld seam was never fully fused. A kind of cosmetic weld seam.  ![[Linked Image from up.picr.de]](https://up.picr.de/45707456lh.jpg) ![[Linked Image from up.picr.de]](https://up.picr.de/45707462wn.jpg) ![[Linked Image from up.picr.de]](https://up.picr.de/45707464ir.jpg) Welding did the trick. Cheers! Phil
Best regards Phil Celle/Germany '62 A 65 Star (disassembled) '69 A 65 Lightning '71 A 65 Firebird
Posts: 2,083 Likes: 96
Posts: 2,083 Likes: 96 |
I would kind of like to see some pics of the bit the OP is talking about ... otherwise what do we have to go on ?
DEPENDING on where it is it is going to be either more or less difficult. as others have said oil residue must be removed ... prefreably with a grinder .
but how are you going to remove the oil inside the tube ?
a MIG welder would be the best
but as i said all speculation without seeing the problem area
I am confused ! ( not unusual ) but are the pics Phil posted the same frame that raf90 seeks advice on ?
Posts: 8,485 Likes: 446
Posts: 8,485 Likes: 446 |
My '72 Bonnie had the same issue, a leak from just above the swingarm mount. I trailered the bike over to my favorite welder. I took the bike off the trailer and removed the rear wheel on the sidewalk in front of his shop. He was able to weld it well enough to stop the leak. However, five years later I'm beginning to see a bit of oil on the back of the frame, might be time to fix again. I'm afraid that the only permanent repair is to take the bare frame to a radiator shop for cleaning so the weld can penetrate properly.
Roadwarrior |
...I am confused ! ( not unusual ) but are the pics Phil posted the same frame that raf90 seeks advice on ? I suppose, yes. The bike is a Firebird Scrambler oif, the frame-# indicates a manufacturing date in July 1971 so raf940's pal Calvin 72 frame very likely will look the same. When re-reading raf940's post, he is talking about the oil seeping around the bracket area, so Calvin's situation could be similar. Given, I am not sure whether or not the bracket with the incomplete weld fusion has been a standard feature or something that has been introduced into manufacturing after some time. Coming back to raf's original questions: The battery was taken out, Podtronics unit was disconnected, the engine could stay in, of course the r/h engine plate and the swing arm went out for the welding, see attached pic. ![[Linked Image from up.picr.de]](https://up.picr.de/45708386uo.jpg) All the best Phil
phil's pic above is exactly the situation.....
ok.... like i said i recon a MIG welder is the tool for the job ... clean it up as best you can and weld it up ... diconnect all the things others have said to and
Robert is your mothers brother .
Posts: 1,673 Likes: 39
Posts: 1,673 Likes: 39 |
The migs the tool, but all traces of oil must be removed to get a clean strong weld. Also, oil can ignite.
Who are the Brain Police?
68 B44 Victor 60 MGA 56 Chevy
Bob M.
