https://i.postimg.cc/mtnsxwY6/Triton-Primary-Drive-078.jpgCant beat the Cork Clutch Plates . excessive slipping will scrorch them like anything else .
those must be about a thousand years old .
A BAG of CORKS , you BOIL THEM ( to soften ) and get a tea spoon ( Do they still make real ones ? )
sit on a stool with the plates on your knee , I suppose if your sensable youll wear gloves . Two Sets'll
get your fingers a tad irritated . Spoon em In . ( have a few spares - try a few - its not rocket science .
THROW the PLATES in a LATHE - Away you go Leave them say 4 mm .
give a quick brush on a sheet of sandpaper , FLAT .
the FEEDBACK & GRIP as you feed in the clutch of the line means you can hold the front a foot off , for the best traction , No problem .
the TRICK with any clutch - Is to FEED IT IN , not ' slide it ' with the motor blipping like a yapping terrier or demented jackle - er salesman .
