1151 break-in miles on a complete crankup rebuild using the best of everything Matching numbers frame, engine and gearbox
Engine Rebuilt cylinder head by Baxter Cycle with new valves, guides and springs, bored +20 with new pistons and Hastings rings, new rod insert bearings, AMR wet sump mod (doesn’t wet sump), cam chain, head bolt and crank hardware, ss rocker feed line, ss exhaust nuts, new gaskets and seals, AMAL Premier carbs, K&N air filter
Frame and Miscellaneous New front and rear vernier isolastic kits, new swing arm spindle and bushings, center stand, side stand and springs, fork tubes, Progressive fork springs, new front and rear rims and spokes with new tires and tubes, rear Shocks, sealed wheel bearings, drive chain, CNW oil tank modification, alloy instrument cups with rebuilt speedo(zeroed) and tach. new front fender, grab rail and chain guard, new headlight shell and lens, new seat, new header pipes and mufflers(slight scratch on rh muffler from kick starter), all new cables and rubber parts. Frame stripped and painted with enamel.
Tins Original Norton metal tank, new metal side covers, base coat/clear coat black, hand pin striping on tank, decal pin striping on side covers, decal logos per factory.
Gear box and Primary New superblend roller layshaft bearing, new high gear bearing, gaskets and seals, clutch rod seal kit, Barnett clutch discs, slight leak from primary felt seal.
Brakes Drilled front disc, rebuilt caliper, new 13mm master cylinder, new pads, ss brake line, new rear brake pedal
Electrical New front and rear wiring harnesses, ignition switch, turn signals, led headlight and tail-light bulbs, warning lights, Trispark ignition, Mosphet rectifier/zener eliminator
One kick starter, pulls strong, idles well. Youtube video of cold start and ride
Send me your email address and I will forward over 30 detailed photos As is where is, No warranty, inspections are welcome by buyer or representatives. Buyer arranges shipping. I can recommend a shipper I have used before. Only form of payment accepted is bank to bank wire transfer of funds Clear Texas title in my name along with bill of sale will be sent via Priority mail when funds arrive.
Sorry to hear you're selling your bike. I kinda lose track, you have others, right?
GrandPaul (does not use emoticons) Author of the book "Old Bikes" Too many bikes to list, mostly Triumph & Norton, a BSA, & some Japanese "The Iron in your blood should be Vintage"
