Topics77,075
Posts792,716
Members12,520
Most Online230 Mar 11th, 2023
Posts: 4,695 Likes: 240
Posts: 4,695 Likes: 240 |
the 1/8 by 40 by 5/8 numbers were my handwriting NOT figures originally in the parts book the screws came from Lowes the new tank just arrived in Leipzig per DHL tracking
1972 Triumph T120 1968 BSA A65 1968 MGB Roadster 1979 Chevrolet Camaro Berlinetta 1969 Honda Mini Trail 2004 Honda Shadow Aero 1949 Ferguson TE20 tractor 1975 yamaha xs650b 2 olive drab WWII military bicycle replicas
been tracking tank DHL progress.......landed in Cincinnatti from Leipzig at 9am this morning (Monday) it's amazing how tracking works it even shows the type of aircraft and takeoff/landing times
Posts: 971 Likes: 113
Posts: 971 Likes: 113 |
Apologies from me, Triumph badge screws are indeed 2BA, BSA could be whatever, I was thrown by this being a Triumph forum, silly me.
Gordon Gray |
tank just arrived today March 22 only took 2 1/2 weeks from time of order to my door in NC.....i opened the box and took it out will post photos tomorrow... initial impressions...tank was very very well packaged encased in layers of styrofoam and bubble wrap like mummy...box was swaddled in shipping tape. paint is very good i would say 8 on scale of 10 it is lined with grey liner no rust or debris inside tunnel width is identical to stock curvature of top is a tiny bit different so will have to tweak trim strips hole in top of tank where trim strip/rubber logo plug goes will need some paint trimmed out supplied cap looks nice the issues so far.........threads for badge holes are useless plugged with paint and not cut very well at all....same with threads on bottom where front brace goes .the petcock holes are not quite as bad but i had to take similar size bolt and work in and out with lube to clean the threads need advice on the badge and brace hole situation.....overall i am pleased the dealer Royal Choppers has excellent customer service/shipping/feedback $200 for a nice tank free shipping halfway around the planet is not to be sneezed at...IMHO
2 members like this:
Jon W. Whitley, Tigernuts |
Posts: 6,661 Likes: 830
Posts: 6,661 Likes: 830 |
Just a suggestion but……pressure test the tank BEFORE adding fuel.
Doesn’t take much pressure or time.
I had to chase my badge holes…..front brace too. But they cleaned up okay and every thing is still where I last put it.
$200…….
Gordon Gray in NC, USA........"Did you shoot our car?"
Jon W. Whitley, pidjones |
$200.............gordon do you recollect what size taps ???
$200.............gordon do you recollect what size taps ??? No sir…..but ours could be completely different. I was having a fiberglass tank copied…..the glass tank didn’t have a front strap…..I had them add that. Mine was also a 1967 so it used the small plastic badge (single screw) and that badge uses a different ( larger diameter) screw than your two hole metal badge. I do know that I have three metal tanks that have front straps and two of those are stock BSA……they all three use the same bolt so a quick look in the parts book could tell you what you could try first. I “think” I asked the guy I got it from what they were????
just got email from royal choppers with pic of my tank and badges installed by them to test screw threads it looks like the screws in old tank are 'nonstandard' so i asked RC to please send screws to me or tell me what size they are they used...... PS they read this forum
Okay I’m thread stealing and if you want to rag me about it……come to this years TSMR and have at it…….
IF they are indeed reading this thread.
PLEASE offer the large metal 2 hole badges in the two options normally seen. NOBODY is offering them…..the supply of reproductions ran out years ago.
I’ll be happy to supply photos of the two options I’m talking about……if you’re a 1968 + BSA fan you already know the ones I’m talking about.
You offer a “ triples” colored badge……you’ll sell 10x more of these.
I’ll go ahead and take two sets of each…
I can be reached on this thread or contact me @ DAD1150 at AOL.Com and I’ll be MORE than happy to discuss.
Sorry Alan……I can’t help myself sometimes.
Posts: 268 Likes: 37
Slow and old
Slow and old
Posts: 268 Likes: 37 |
My T150 tank is supposed to use 2BA screws, but I re-tapped (had to anyway - really fouled threads) to 10-32 and bought 10-32 screws at my local ACE hardware. just a tad undersized, but I red Locktite'd them and they should hold fine. I did grind down the heads a bit so they looked better. BTW, I used socket-head screws.
"Love 'em all.... Let GOD sort 'em out!"
royal choppers informed me that they use size M4 screws in badge holes that being the case i now suspect brace holes are metric too will investigate once i have some coffee and git my britches on guess i will be going to local hardware
Jon W. Whitley |
the finished 'project' would i buy another tank from them? yep. ![[Linked Image from i.postimg.cc]](https://i.postimg.cc/SxMzyRyc/IMG-4511.jpg)
Jon W. Whitley, HughdeMann |
Posts: 2,135 Likes: 124
Posts: 2,135 Likes: 124 |
My T150 tank is supposed to use 2BA screws, but I re-tapped (had to anyway - really fouled threads) to 10-32 and bought 10-32 screws at my local ACE hardware. just a tad undersized, but I red Locktite'd them and they should hold fine. I did grind down the heads a bit so they looked better. BTW, I used socket-head screws. A 5 mm screw is only slightly larger than a 2BA, which is around 4,7-4,8 mm, and the pitch is the same. Tapping the hole to 5 mm is very easy and usually does the trick. SR
Jon W. Whitley |
Posts: 1,538 Likes: 42
Posts: 1,538 Likes: 42 |
That looks bloody beautiful RAF940! Royal Choppers is the name to remember by the look of it.
Jon W. Whitley |
thanks actually i've had the bike about 11 years and decided to freshen it up new tank pipes fork boots LED headlite bulb lots of fresh oil/grease/spit/polish/tires.....
Slow and old
Slow and old
Beautiful bike! Hope to see it in-person at the Possum Gathering in Sevierville May 12 & 13!
Posts: 1,641 Likes: 97
Parts Dealer
Parts Dealer
Posts: 1,641 Likes: 97 |
I got a tank from them for a Matchless Paint was off from the location of the tank badges and the screw holes were off
If you look at the back of the tank once its mounted on the frame, it was tilted
Looks good tho
I plan on purchasing another tank from them and doing a review
Jon W. Whitley |
put gas in tank last night went out this morning and checked it over no runs no drips no errors
Jon W. Whitley |
