Topics77,101
Posts793,026
Members12,524
Most Online230 Mar 11th, 2023
Posts: 5 Likes: 1
Posts: 5 Likes: 1 |
K&N Closeouts - Britcycle Bulletin March 14th 2023
Sale Item
[Linked Image] 70-9270 OIL LINE ASSEMBLY, ROCKERFEED, BSA A75 & TRIUMPH T150, EARLY This New Old Stock assembly contains a 70-6353 herringbone hose, 70-9271 and 70-9274. For 3/16” oil line. 30% OFF
Did You Know We Have:
[Linked Image] 562-01 CRASH BAR, UNIVERSAL Dimensions: gap 7-3/8", outside widest 26-1/2", depth 14", 1" diameter tubing. Limited stock. From the 70s! No brackets. [Linked Image] 721-T74X 721-T74X EXHAUST PIPES, TRIUMPH 69 & 70 TR6C, HIGH, LEFT HAND 1-3/8" OD outlet; used with H pipe 70-9673. Only 1 set on hand at this time!
K&N Closeout K&N products are no longer being distributed by BCS due to unrealistically huge annual order quantity requirements, so we have some good deals at old prices while they last![Linked Image] Very Limited Quantities on All
See also 06-0673/C AIRFILTER ASSY, NORTON DUAL 930, THIN. Made in the USA, but no longer a K&N product. NEW BATCH JUST RECEIVED.
631-11 OIL FILTER, INLINE, WASHABLE, K&N K&N inline fuel/oil filters are ideal for racing applications. The filter housing is made from highly-durable anodized aluminum and the filter media can be used to filter a variety of oils and fuels including methanol. The filter material is made from stainless steel and is designed to be washable and reusable. [Linked Image] 03-3188 ELEMENT, AIR FILTER, NORTON P11, K&N [Linked Image] 633-RC17 K&N FILTER, AMAL 376 & 600 For T150 and T100R; should also do Hurricane and X75 633-RC2870 AIR FILTER, K&N, Mikuni 26 & 28MM [Linked Image] 633-RU1760 K&N FILTER ASSEMBLY, Mikuni 36/38MM, ANGLED According to one customer, great for 38MM Mikuni on a BSA B50 or twin carb A65 racer [Linked Image] 633-621220 FILTER, CRANKCASE, T160, K&N For use when replacing stock air filter with 3 x 633-RC16
And don’t forget the filter oil! 231-08 FILTER OIL, K&N, 8 OZ.BOTTLE
British Cycle Supply Company info@britcycle.com
604 Davison Street, Robinson Corner (Wolfville), NS, Canada B4P2R3 In Canada call 902-542-7478and 50 Connecticut Rd, Loring Commerce Centre, Limestone, ME, USA 04750 USA and International call 201-880-0366Fax: (902)542-7479
