Three issues to look into
Removing Triumph sludge tube
by reverb - 05/08/23 7:30 pm
No Name Man
No Name Man
SE Ohio
Lannis 90
DavidP 80
Allan G 66
Lannis 44
Cyborg 23
raf940 22
12,520 Registered Users
Topics77,075
Posts792,716
Members12,520
#904769 03/10/23 1:04 am
Hi all,
As mentioned in an earlier thread I am the proud owner of the Thunderbird that has been in the family since 1959. I have stripped it down to the frame. I have the motor on a stand but while I was clearing out the sidecar I noticed a receipt for a full engine overhaul 2 years before my father passed. He died in 2011 & the bike has been stored since then. It would have only travelled 2,000 KLM since the rebuild. The motor turned over easily & has plenty of compression. I was thinking of removing the head, reseating the valves, decoking the pistons & having a look at the barrell etc. Do you think this is the logical thing to do rather than pull the whole thing apart, any suggestions??
1955 6T Thunderbird with sidecar (been in family since 1959)
1952 6T frame
Numerous engines & boxes
Triumphs on eBay
Originally Posted by AussieDerek
It would have only traveled 2,000 KLM since the rebuild. The motor turned over easily & has plenty of compression. I was thinking of removing the head, reseating the valves, decoking the pistons & having a look at the barrel, etc. Do you think this is the logical thing to do rather than pull the whole thing apart, any suggestions??
Sounds like an engine that is ready and waiting to be run again. Why take it apart? If it ain't broke, don't fix it. Fire it up and enjoy.
1971 BSA A65 650 - Project
"Charlie don't surf"
Does the receipt detail all the work carried out in the "full engine overhaul"
Might be worth posting a copy of the receipt and get the comments of different people.
However if it was a genuine full overhaul then I agree with Jon----change the fluids, test out that you have sparks and that the carb holds gas then if all looks good go for a start up.
I agree with the two above, it would be nice to know what the full overhaul entailed. If the receipt doesn't specify details, you may be able to contact the guy (I presume) who did it. With only 2000 km on it and good compression the top end must be good, no de-coke or re-seating necessary. It would be a waste of time to mess with it. If you were to look at anything, you'd want to open the crank and check for built up crud in there, in case it wasn't done at the overhaul. However, the built up crank demands some level of mechanical aptitude to work on, as the six 1/4" bolts must be tightened to a pretty exact load. Using a normal torque wrench on all the bolts can't be done, unless you device something special. The fitters at the factory apparently had it in the wrist, which, hopefully, do I...
In conclusion, I'd leave it and trust it's OK.
SR
Slow and old
Slow and old
I would pull the carbs and clean them, carefully noting previuos settings and returning same. New tires and check brakes out.
"Love 'em all.... Let GOD sort 'em out!"
