Topics77,075
Posts792,716
Members12,520
Most Online230 Mar 11th, 2023
Posts: 284 Likes: 29
Posts: 284 Likes: 29 |
Mark, how on earth do you ride that with clip-ons/ace bars and forward footrests? My back would be in about 3 pieces after about an hour. has been posted earlier, but no problem with the riding position it is for this bike I'm searching for an alu-tank https://swf-ignitionsystems.nl/wp-content/uploads/2021/08/MNDY87551.mp4
Posts: 390 Likes: 18
Posts: 390 Likes: 18 |
I have always wondered why no one has tried polypropylene to make a BSA Spitfire tank.
The Devil is in the details.
1957 BSA A10 Spitfire Scrambler (numbers matching, very correct, very nice condition) 1965 BSA A65 Lightning Rocket "Clubman" (restored) 1966 BSA A65 Spitfire MK-II (restored) 1967 BSA A65 West Coast Hornet (under restoration) 1975 Norton Commando Roadster (2100 miles) 2001 Kawasaki W650
Posts: 5,733 Likes: 258
Posts: 5,733 Likes: 258 |
If you mean a plastic tank like many modern bikes, they are roto -molded. You have to make a mold and find a shop that will make the three or four you might sell.
Posts: 864 Likes: 39
Posts: 864 Likes: 39 |
How about a graphite epoxy tank or epoxy glass tank. You would cut the bottom out of a bad glass tank and make a plaster Paris mold to lay in the cloth. I think the upper tank could made from laminated wood saw cut and shaped so it would fit into the original tank. A router could carve out the fill cap cap area and a thin wood star pattern chiseled out for the transfer stat. If you have a bridge port mill you could really carve out a nice wood pattern. Using the pattern to lay up a ridged mold spray in the gel coat then lay in the cloth to lay in the cloth . The mold is reusable The story goes at BSA workers were giving tooling to take home to build the tank in one evening. Many of which you will find a signature or initials scratched into the bottom. I know I’m over simplifying it but can’t be that hard. Guys a making electric starters, belt drives and end feeds etc.
You would have to coat the inside with something to keep the ethanol from eating the epoxy. I am not sure you could use Caswell with fibreglass, hardens too quickly.
No, the deal is epoxy resin does not need lining, the polyester resin does. So making a tank out of epoxy resin or carbon fiber impregnated with epoxy resin would not need lining
As I understand it, only phenol novalac epoxy is resistant to ethanol. Other types will soften. However, might be irrelevant as california does not allow fibre glass fuel tanks to be sold for road use. I do not know if Spitfire tanks are grandfathered in.
Posts: 318 Likes: 8
Posts: 318 Likes: 8 |
I purchased a steel tank from Baxter. Very nice. He may still stock them, it has been some time ago.
