Miscellaneous:
Went through a box with an odd collection of hardware. Mostly Trident, all worthless. This stuff doesn't make the cut. I'll throw some of this stuff in the box if you buy a box. Otherwise, off you go!
I recognize T140 head nuts, fork lock, T120/T150 fender mount brackets.
The bolt on the bottom right is a special bottom shock mount fastener for a Rocket 3 with a low height head to clear the brake rod. I'm proud of my brain for recognizing this in my old age.
Original Bolt, VERY valuable! Do A65's have this feature?
![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/19039/filename/DSC00706.JPG)
