Upgrade your membership to Premium Membership or Gold Membership or even Benefactor
10% Off Girling at The Bonneville Shop 2/3-2/9/23
by The Bonneville Shop - 02/03/23 6:14 pm
by Morgan aka admin - 02/09/23 12:52 pm
Benefactor ✅
by Morgan aka admin - 02/09/23 11:15 am
Buy BritBike staff a coffee ☕️ or pint 🍺
by Morgan aka admin - 01/15/23 9:29 am
Mountain that speaks
Scottsville, NY
Lannis 90
DavidP 84
kevin 56
Kev. 32
DavidP 26
Lannis 26
Igloo, patrickblue, j-bud, Uneasy Rider, Mally
12,395 Registered Users
Topics76,568
Posts784,697
Members12,395
Most Online204
Jul 10th, 2022
#901136 01/25/23 3:14 am
Novice poster
Novice poster
Hello all I have come across a pair of H&C triumph cams I have a catalog from 67 and the number isn’t in that I was wandering if anyone has information on the 6976-9 number thanks for your help
Seems H&C are set symetrically , http://vintagebikemagazine.com/wp-content/uploads/2017/08/HarmonCollins.pdf
Theres a few mentions in early 60s Cycle World , Desert Racers & Flat trackers .
Heres some other blather , https://www.classicbritishspares.com/blogs/news/best-triumph-camshaft-set-up
the LIFTERS are where youre gunna get got . Apparently the thruxton cam was the old T-Bird Cam , With LARGE RADIUS LIFTERS .
A lod mega racer , had said they / He , put ' FLAT ' followers in a speedway chair T 100 . You had TO WATCH that the Lifter Lower Corner
did not dig into the cam lobe flank .
Id think a few trial assemblies - a case half , barrel & followers . or if youve a past it barrel , take a hacksaw to it , so theyre observable .
THE OLDE .020 clearance , for mucking about with openings and closings . To Late on the ex & to Early on the int & theyll tangle .
No Way would I set the valves back in the head to get the clearance on overlap . but HELE did on the 500 racers for the Daytona Race .
Hopefully someone'll come up with the Exact specs for that number camshaft .
CAN YOU TELL US What the LIFT Is ? .
looks like theres a TIMING SPEC. SHEET here , but youd need to log in to see it ?
. https://www.jockeyjournal.com/threa...man-collins-roller-lifter-advice.167801/
If theyre big square things they might be the roller type , If theyre ' peaky ' lobes , theyre likely otherwise .
Gotta Picture , or two .
might be usefull , https://www.britbike.com/forums/ubbthreads.php?ubb=showflat&Number=462961
& contact these guys , re H & C cattledog . http://www.crazyhorsespeedshop.com/history-of-harman---collins.html
Er . . . spec. book . perhaps . it'd pay to ASK FIRST . Those blokes'd know. youd think .
1 member likes this: Trophytr6c
Novice poster
Novice poster
Thanks the spec sheet has it listed the specs are the same as what they earlier called the number 9
Stay away from crazy horse. Just sayin.
Moderated by  Allan G
