... or the 'ol rope trick.
find TDC, on compression stroke so valves are closed. rotate engine opposite the direction you want to turn the nut. go to bottom center. stuff rope in the spark plug hole. I like 9mm Perlon climbing rope. pull up against it and there ya go. done it many times. once on a
Honda CVR with a broken timing belt in the middle of a lava field
