The breather definitely screws off. I know that because my breather is missing.. There's a fine- threaded stub that sticks up the breather screws on to. In the parts diagram it shows the breather on the oil tank with what looks like a thin locking nut under it. Presumably the arrangement is so the breather can be directed in whatever direction you want. I've got a later steel oil tank that has the same breather but it is definitely not screwed on. It's likely been brazed in position.
Ken
Eastern Ontario
Gotcha........I misread your first post and turned "stub" into "stud" in my head. Sorry.
You sir are 100% correct.......it screws off. Something I didn't know before your post and I thank you for bringing it up. Odd that there doesn't seem to be a part number for it. Looks to be part of the tank in the parts book. Those flats should have been a dead giveaway. BUT it took some force to get it started.....looks like they used a thread sealer?
![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/18792/filename/IMG_0245.JPG)
![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/18793/filename/IMG_0246.JPG)
I love the sculpted look of the fiberglass......but I've learned to like the metal fuel tanks, especially with our fuel. But both of my Roadsters and my C-25 still have the fiberglass oil tanks.
Have no clue what the text on the bottom of the tanks means........but all my Fiberglass tanks carry these type of birthmarks. Always pretty crude.
Ken......IF that one looks like it'll work for you......I'd be happy to send it to you? I'll PM you.
