A bit of a rookie question .... I'm building up a bike from parts and am reassembling the brake hub from a QD wheel. I have all the correct parts, its just how to assemble them!
The parts book is a little hard to read, can anyone whelp me with the positioning of the the following parts ....
In the brake drum there is a sealed bearing held in place by a retaining circlip.
~ Where does the shim 67-6033 fit in the puzzle - Brake Drum or Wheel Hub?
~ Where does the Thrust Washer 65-5884 fit in the puzzle, again in the Brake Drum or the Wheel Hub?
Any assistance is gratefully received. As the bike is a build up and the wheel was incomplete, I don't have the original set up to work with.
I'll try and add a picture here:
[img]http://https://www.advrider.com/f/threads/bsa-b44-vs-rear-wheel.1618153/[/img]
