Topics76,566
Posts784,683
Members12,395
Most Online204 Jul 10th, 2022
Posts: 373 Likes: 2
Posts: 373 Likes: 2 |
The clutch on my A65 slips some when it’s cold and after a few minutes it is fine. I’ll try a few adjustments first.
Posts: 1,379 Likes: 489
Posts: 1,379 Likes: 489 |
Yes, do the adjustments first. A too tight clutch push rod can cause that problem.
Allan G |
Posts: 6,112 Likes: 150
Posts: 6,112 Likes: 150 |
The clutch discs swell with heat, especially the cork ones, so they will provide more clearance when cold and less when hot. I adjust mine so that I can back off the handlebar adjuster to start & ride a mile or so, and then bring it back up as it warms up. Adjust at the pressure plate when the engine is warm and the handlebar adjuster is backed off. Back the screw off from seated just a hair, maybe 1/4 turn, then bring the handlebar adjuster up to about 1/4" cable free play. Adjusting this way, I find that, when the bike is cold, there is NO cable free play at the clutch lever, so I back it off to get that 1/4" free play. As the engine warms, the slack increases, so then I bring it back up to 1/4".
If this sounds weird, I'll mention that the original BSA clutch discs did not swell like this. Also, I've only had limited experience with Surflex discs, but I believe they don't swell as much as the cork ones either.
'65(lower)/'66(upper, wheels, front end, controls)/'67(seat, exhaust, fuel tank, headlamp)/'70(frame) A65 Bitsa. 2007 Triumph Bonneville Black
Posts: 6,181 Likes: 303
Posts: 6,181 Likes: 303 |
1/4 turn will work fine, but as the clutch wears this clearance closes fast , better to go with at least a half turn, the factory manual asks for one whole turn. This is set cold. It could be a few things, oil type, general wear and tear, bad cable, if the adjustment doesnt work.
Posts: 8,993 Likes: 305
Posts: 8,993 Likes: 305 |
When you set up the clutch adjustment at the pressure plate. Do it with either the cable having loads of slack or disconnected at one end. If there is any chance that cable is removing any free cable inner before you start then your already potentially on a loosing battle.
Now lets all have a beer!
When you set up the clutch adjustment at the pressure plate. Do it with either the cable having loads of slack or disconnected at one end........ Cable loose but just enough adjustment so you can squeeze the lever and put some pressure on the clutch push rod when the lock nut is tightened up. This helps keep the adjuster pin from turning on you and screwing up your adjustment.
When you set up the clutch adjustment at the pressure plate. Do it with either the cable having loads of slack or disconnected at one end........ Cable loose but just enough adjustment so you can squeeze the lever and put some pressure on the clutch push rod when the lock nut is tightened up. This helps keep the adjuster pin from turning on you and screwing up your adjustment. Another way to do that is to have a socket with a hex fitting on the back end, run a screwdriver through the socket to hold the adjuster screw in place, and turn the socket with an open end or ring spanner. (You can also turn an ordinary socket with vise-grips, but that mars the socket.)
Allan G |
.......Another way to do that is to have a socket with a hex fitting on the back end, run a screwdriver through the socket to hold the adjuster screw in place, ...... Yep, that works too. The OP is going to be a clutch adjusting maestro by the time he's done.
