Bulletin March 14th 2023
by Morgan aka admin - 03/21/23 6:58 pm
AussieDerek
AussieDerek
Wangi Wangi, NSW, Australia
DavidP 83
Lannis 68
kevin 37
John R, Commando1775, Murph, Jeff Pow, Stephen Anthony
12,439 Registered Users
Topics76,777
Posts788,039
Members12,439
#899920 01/10/23 9:37 pm
Novice poster
Novice poster
hi all
my c-15 gearchange is 1 up for 1st then down for 2,3&4, yet the manual says 1 down for 1st then up for 2,3& 4 why is mine different ?
cheers
mike
Hi Mike and welcome to the forum.
This is an easy one.
Someone has installed the shift camplate upside down either on purpose so he could imagine he was on a Gold Star (or Norton, or a BSA A10/A7/B31 or...). Maybe it was just what he was used to. I've heard of that happening.
Or, it was a mistake. Take your pick.
Changing it if you decide you need to means removing both RH side covers, but you don't usually need to disassemble the clutch side, unless of course you find something else wrong that makes going in deeper a good idea.
Best of luck with it.
If you plan to buy a Norton or a pre unit BSA in the future do nothing, if you plan to buy a Triumph then change it now.
For a C15F or C15G is an easy swap, more work involved with the earlier C15's.
All my BSA Unit Singles follow the Norton pattern as I have equal numbers of both.
Novice poster
Novice poster
hi Stuart
many thanks for answering my c-15 gearchange question,i will have many more questions im sure before my c-15 is back on the road
cheers mike
I SO wanted your location to be Australia! (or anywhere in the antipodes for that matter).......... The merry quips and general witticisms could have been boundless.
