Upgrade your membership to Premium Membership or Gold Membership or even Benefactor
10% Off Girling at The Bonneville Shop 2/3-2/9/23
by The Bonneville Shop - 02/03/23 6:14 pm
by Morgan aka admin - 02/08/23 12:00 pm
Buy BritBike staff a coffee ☕️ or pint 🍺
by Morgan aka admin - 01/15/23 9:29 am
MikeG
MikeG
New Hampshier USA
Lannis 90
DavidP 87
kevin 56
Kev. 32
Lannis 26
DavidP 26
Igloo, patrickblue, j-bud, Uneasy Rider, Mally
12,395 Registered Users
Topics76,566
Posts784,685
Members12,395
Most Online204
Jul 10th, 2022
DAMadd Offline OP
Swapped b44 inner timing cover for one that was in with some parts. After pulling the main shaft to dress the bushing from my binding issue. Noticed a hairline crack in the vicinity of the main shaft bearing, possibly just an imperfection in the casting but the laws of probability made me swap it. Re bushed re- bearinged all fit for smooth operation.
Before final reassembly was cleaning it up
I noticed that it didn't have the small "weep" hole on the transmission side. I scoured RR to find if it has any effect to no avail. The tiny hole on the lower engine side is there but my old inner also has an upper one in the transmission section. Does this effect anything? I could drill it but is there any reason to?
65 TR6R 68A65T 69 B44VS. 74 T150V 65 A65 D L/R
19 Chieftain
If your dip stick does not have a breather slot cut in the threads then the small hole in the upper part of the gearbox is needed. Sometimes it is in the gear change section and others in the outer cover on the twins. Presumably similar on the singles. I have to check my B50 case if it has the dip stick slot or hole.
DAMadd Offline OP
There is not any relief in the dipstick thread. Query solved, drill it is. While there is info in Ratio about the oil drain back there isn't any about trans pressure.
Thanks Dave!
19 Chieftain
