Topics76,566
Posts784,685
Members12,395
Most Online204 Jul 10th, 2022
Posts: 2,410 Likes: 451
Posts: 2,410 Likes: 451 |
i run 9.5 to 1 in a 72 T120, which has a lousy head compared to the A65, i think.
its been twin plugged and i pour in 87 r+m/2 gasoline with no difficulty.
twin plugging is harder to do on an A65 but there are people on this forum who have done it. It does little for them, as you say the head is good for a hemi anyway, high plug, shallow dome etc.
I suppose talking 'Pool' petrol would make the use of 9-1 'high compression'. I wasn't aware we were still at war.................................. If thats's the case i'll just nip out and buy a gallon of TEL eh?
with fuel since the late 60's people have run 12-1 and higher on race tracks and some cars including the old 60's v8 rovers were 10-1+.
As for squishing the heads and getting massive turbulence in the combustion chamber, you can look at the 'Mays' head that Jag did for the V12 as a strange example.
Posts: 9,283 Likes: 226
Posts: 9,283 Likes: 226 |
In the context of British 650s, 9:1 is high compression.
Look at the range of compression ratios used as standard on the bikes they sold for road use. Where is 9:1 placed in that range?
Need to look for similar cylinder head layouts really. SS norton, Norton Commando, triumphs were 8.5-1 but head was very domed. Matchless 650gsr around 8.9-1. Enfield (late intecepter) So i stand by my comment 9-1 wasn't exceptional given that the head was better than most at the time. First step on any tuners ladder was to use higher compression normally. You could buy 11-1's for triumphs, beezers, nortons etc.
Posts: 6,112 Likes: 150
Posts: 6,112 Likes: 150 |
Back in the seventies, the people I knew and rode with, with 650 and 750 BSA and Triumph twins, went around in a questionable state of tune half the time, but no one suffered from pinking as I recall. But that was when you could get 95 octane leaded ethanol-free fuel at the pump. So at that time, 9:1 pistons was considered "normal", or not problematic. I do recall though, a friend with a Camaro Z28 with 11:1 or 12:1 pistons talking about having to seek exotic fuel.
'65(lower)/'66(upper, wheels, front end, controls)/'67(seat, exhaust, fuel tank, headlamp)/'70(frame) A65 Bitsa. 2007 Triumph Bonneville Black
Posts: 2,021 Likes: 75
Posts: 2,021 Likes: 75 |
Consumer Magazine did an article here about the weed killer we are being sold ... They had it tested and reckoned that the so called 91 was actually more like 85
