I was going to put Amal concentric's on -- I have angled rubber connectors and was going to come up with a adapter to the flange mount. I can measure the intake stubs OD and length if you want-- I think these E heads are intended to mount the Amal Mark 2 newer style carbs. I'm not clear on what you mean by V carbs.
So the rubber connectors are still going to require an adapter to the flange...? The E head is indeed meant to be used with the later MK II carbs and I am not familiar enough with the mounts to just send the head. Yes, perhaps some measurements would help.
If the straight routing of the mounts would not allow use of the stock air filter housing, that is not a big ta-do.
By V carbs I meant the carbs that come on a '78 T140V...
AMAL 930s.
Rob
![[Linked Image from imagizer.imageshack.com]](https://imagizer.imageshack.com/v2/640x480q90/924/qdSaSK.jpg)
