Bulletin March 14th 2023
Ron Pare
Ron Pare
Salem, MA
DavidP 85
kevin 55
kevin 34
GTO68, PKR, Frank4, Bob Mayer, KurtV
12,432 Registered Users
Topics76,758
Posts787,762
Members12,432
#897336 12/06/22 11:56 am
I fitted an Alton starter some years ago ,and have had various problems ,ie rotor stator several times but the most is that it wears out the brushes ,I
have had to replace 3 brush sets in 4 years , and now they are hard to find , Alton has not replied to any emails, has anyone else had this problem?/
the commutator is in good condition
baz
Norton on eBay
Alton is on Facebook.
Try writing to Paul on Facebook and see what he has to say.
.. Gregg
Lucas & BTH Magneto Restoration
Lucas & Miller Dynamo Restoration
SMITHS Chronometric & Magnetic Instrument Restoration
[email protected]
gregk tried that 3 times no replies as yet
baz
Not a good sign, baz. Paul is usually very good with customer support.
If you like, I will write to him. What exactly would you like from them: just a set of brushes?
.. Gregg
[email protected]
well thank you, 1st I would like to know why the brushes are wearing out so quickly ,and where i could buy some as the OZ agent has sent me a s/hand set
and has no more left
cheers baz
Not local to you but I have gotten brushes from carbonbrush.com. They have all sorts of styles and dimensions.
1 member likes this: dommie90
Baz,
I contacted Paul at Alton this morning and explained the situation to him.
Paul will be contacting you directly to sort it out.
.. Gregg
[email protected]
gregg-k, I have sent Paul all my info plus photos , waiting for his opinion on what could be wrong
cheers baz
How have you determined this ?
With so many problems, has this been machined - or even filed - down ?
Even just as a precaution ...
Rohan there is no undue wear or grooves it has been checked every time that I have replaced the brushes ,
I have had an auto leky look at the commutator and can find no fault with it
baz
baz, I'm confident that Paul will sort it out for you quickly. He has lots of those starters out in the field, and they are not known for brush wear.
Could it be that the previous brushes were the correct dimensions, but made from the wrong grade of material?
,,, Gregg
[email protected]
GREGG,could be but 3sets worn out in 4 years seems strange ,I dont mind replacing the brushes except I have to remove the whole primary and clutch side
just to get at the start motor ,I am getting quite good at it now hahahaha
baz
Moderated by  Dave Comeau
