Topics77,072
Posts792,655
Members12,520
Most Online230 Mar 11th, 2023
Posts: 209 Likes: 6
Posts: 209 Likes: 6 |
I fitted an Alton starter some years ago ,and have had various problems ,ie rotor stator several times but the most is that it wears out the brushes ,I have had to replace 3 brush sets in 4 years , and now they are hard to find , Alton has not replied to any emails, has anyone else had this problem?/ the commutator is in good condition baz
Posts: 1,282 Likes: 24
Posts: 1,282 Likes: 24 |
Alton is on Facebook. Try writing to Paul on Facebook and see what he has to say. .. Gregg
Spyder Integrated Technologies Lucas & BTH Magneto Restoration Lucas & Miller Dynamo Restoration SMITHS Chronometric & Magnetic Instrument Restoration [email protected]
Posts: 209 Likes: 6
gregk tried that 3 times no replies as yet baz
Not a good sign, baz. Paul is usually very good with customer support. If you like, I will write to him. What exactly would you like from them: just a set of brushes? .. Gregg
Posts: 209 Likes: 6
well thank you, 1st I would like to know why the brushes are wearing out so quickly ,and where i could buy some as the OZ agent has sent me a s/hand set and has no more left cheers baz
Posts: 5,733 Likes: 258
Posts: 5,733 Likes: 258 |
Not local to you but I have gotten brushes from carbonbrush.com. They have all sorts of styles and dimensions.
dommie90 |
Baz, I contacted Paul at Alton this morning and explained the situation to him. Paul will be contacting you directly to sort it out. .. Gregg
dommie90 |
Posts: 209 Likes: 6
gregg-k, I have sent Paul all my info plus photos , waiting for his opinion on what could be wrong cheers baz
Posts: 5,203 Likes: 130
Posts: 5,203 Likes: 130 |
the commutator is in good condition How have you determined this ? With so many problems, has this been machined - or even filed - down ? Even just as a precaution ...
Posts: 209 Likes: 6
Rohan there is no undue wear or grooves it has been checked every time that I have replaced the brushes , I have had an auto leky look at the commutator and can find no fault with it baz
baz, I'm confident that Paul will sort it out for you quickly. He has lots of those starters out in the field, and they are not known for brush wear.
Could it be that the previous brushes were the correct dimensions, but made from the wrong grade of material?
,,, Gregg
Posts: 209 Likes: 6
GREGG,could be but 3sets worn out in 4 years seems strange ,I dont mind replacing the brushes except I have to remove the whole primary and clutch side just to get at the start motor ,I am getting quite good at it now hahahaha baz
