Upgrade your membership to Premium Membership or Gold Membership or even Benefactor
Triumph 650/750 High-Output Alternator Kit
by The Bonneville Shop - 01/13/23 11:29 pm
Missing edit button
by wrench136 - 05/30/22 2:57 pm
by Morgan aka admin - 01/28/23 3:01 pm
Buy BritBike staff a coffee ☕️ or pint 🍺
by Morgan aka admin - 01/15/23 9:29 am
Benefactor ✅
by Morgan aka admin - 01/08/23 8:38 pm
by Morgan aka admin - 01/03/23 6:30 pm
British Fasteners Specs
by Morgan aka admin - 01/03/23 1:29 pm
Kent Shaun
Kent Shaun
Kent Garden of England
Lannis 76
DavidP 64
Kev. 36
DavidP 25
sam keller, Raz, HermDawg, 47sqfour, Blackdoctor
12,383 Registered Users
Topics76,514
Posts783,703
Members12,383
Most Online204
Jul 10th, 2022
#897152 12/03/22 10:42 pm
Emlupi Offline OP
Good evening all,
I am currently doing parts inspection on my ‘67 T120 TT project. I was taking measurements on the crankshaft surfaces and found the drive side main bearing journal to be slightly under spec and somewhat oval. A photo with the measurements is below.
If I try to reinstall the old roller bearing onto the journal it goes on pretty easily with a slip fit. The manual calls for journal dimensions of 1.1247-1.1250” and the bearing to be a “tight push fit” on the crank. So, what are my options to remedy this situation? Any and all advice is greatly appreciated. Thanks.
Here’s a couple of pictures showing the crank journal and bearing .
Triumphs on eBay
Emlupi Offline OP
I have looked to see if I can locate any of the bearing size markings such as O, OO, OOO, etc. I found this marking etched onto the inner and outer races. Not sure what it means, maybe someone with intricate knowledge can explain.
Parts Dealer
Parts Dealer
Send it to Marine Crankshaft and have it welded
I have done this a few times
See my post on this very subject
https://www.classicbritishspares.co...-bearing-on-a-vintage-triumph-crankshaft
Emlupi Offline OP
Thanks very much for that information, extremely helpful.
Parts Dealer
Parts Dealer
No worries
If you do send your crank out for welding, make sure they DO NOT grind the face of your crank
Tell them to leave the depth (length) of the journal the same with the proper radius
Ask me how I know.....
