Upgrade your membership to Premium Membership or Gold Membership or even Benefactor
Triumph 650/750 High-Output Alternator Kit
by The Bonneville Shop - 01/13/23 11:29 pm
Missing edit button
by wrench136 - 05/30/22 2:57 pm
by Morgan aka admin - 01/31/23 2:14 pm
Buy BritBike staff a coffee ☕️ or pint 🍺
by Morgan aka admin - 01/15/23 9:29 am
Benefactor ✅
by Morgan aka admin - 01/08/23 8:38 pm
by Morgan aka admin - 01/03/23 6:30 pm
British Fasteners Specs
by Morgan aka admin - 01/03/23 1:29 pm
Morgan aka admin
Morgan aka admin
Sävedalen, Sweden
Lannis 77
DavidP 74
Kev. 36
DavidP 25
BSA A65 rebuild, Dan Haggard, Padsdad, sam keller, Raz
12,386 Registered Users
Topics76,525
Posts783,968
Members12,386
Most Online204
Jul 10th, 2022
Spino Offline OP
Hello. Another question for you all as I reassemble the bottom end on my ‘68 Victor 441 project. The nut that holds the alternator rotor onto the crankshaft will only go about halfway on before it stops. I’m pretty confident the crankshaft sprocket is all the way onto the splines and that the rotor is flush with it. Am I correct in assuming it isn’t right to have this nut hanging off the end of the crankshaft? Any suggestions? Thanks!
https://flic.kr/p/2o3HoFK
Spencer
1968 BSA B44 in progress
1974 BMW R75/6 on the road
2015 KTM 250XCW on the trail
Where you need to look is behind it? That nut only holds stuff in place......but stuff's gota be in the right place.
My answer to your question is "No sir, that nut in the photo isn't right"
Gordon Gray in NC, USA........White man broke the code
Has part of the threaded stub been cut off?
Spino Offline OP
Something else I noticed: The parts fiche calls for a Lucas 54213901, but this is a 54212006. Is it possible this rotor is too thick for the crankshaft, or were they interchangeable? Tolerance between rotor and stator is correct per manual spec, so diameter is good. Thanks!
Spencer
Yes rotors come in different widths
And Yes the nut is totally wrong
nut should look like this [Linked Image from img.auctiva.com]
1 member likes this: Spino
The rotor should be about 1.35 inches wide based on what I have in the shop. The shaft end does look a bit sawn off.
I'll try to be a little more helpful. This is a ragged out B50 but this measurement should be close enough.
Is the shaft key set correctly? If not, the rotor may not go on all the way.
Who are the Brain Police?
68 B44 Victor
60 MGA
56 Chevy
Bob M.
