Upgrade your membership to Premium Membership or Gold Membership or even Benefactor
10% Off Girling at The Bonneville Shop 2/3-2/9/23
by The Bonneville Shop - 02/03/23 6:14 pm
by Morgan aka admin - 02/04/23 2:40 pm
Buy BritBike staff a coffee ☕️ or pint 🍺
by Morgan aka admin - 01/15/23 9:29 am
Benefactor ✅
by Morgan aka admin - 01/08/23 8:38 pm
Denis J
Denis J
Sacramento, CA
Lannis 84
DavidP 83
Kev. 34
DavidP 27
Uneasy Rider, Mally, Daveed, 70Triumph, Knight57Corv
12,392 Registered Users
Topics76,551
Posts784,416
Members12,392
Most Online204
Jul 10th, 2022
Page 2 of 2 1 2
I used to do milling and I tried to get to as great a level of accuracy as possible (to the annoyance of the foreman, who was more interested in speed). I remember using a vertical mill with a 6" TCT cutter (that may be the type you refer to - they have removable square TC cutters which clamp into the cutter body). I found this would work very well on aluminium when using a high cutter speed (and with fresh cutters). Faces being out of parallel is often an issue with old Triumph heads. Parallel bars under the workpiece, shimmed with shim steel can get the upper face nicely parallel with the table.
I certainly agree on the oil blackening. On a rebuilt engine the oil should stay looking new after 5 minutes running, and still look pretty much like new after 100 miles or more. Back in those days, diesel engines were regarded as things to be thrashed mercilessly and never much thought about, other than oil & filter changes now & then. They were very crude compared to modern diesels. On a Triumph, cleaning out the oil tank is, I'd think, quite important - can be very important if not done for an unknown period. The gelatinous goop that can accumulate can be shocking!
Triumphs on eBay
Richrd Offline OP
I normally take oil tanks to radiator shop and have them boiled out. they pressure test and strip all the paint. I don't remember what was done with this one, but I'm sure I at least checked it.
looking in with a flashlite there is no evidence of gelatinous goop.
Rich
75 commando
a ducati
Another couple triumphs
and no Honda?
but another triumph
That seems a very good way of doing it.
Hi , You didn’t hear this from me, but Gasoline is about the strongest solvent on the market that doesn’t damage most paints. Acetone is very effective, but it can damage paint in 1 heart beat.
I like diesel fuel. Good solvent, not as dangerous as gasoline.
Page 2 of 2 1 2
