Upgrade your membership to Premium Membership or Gold Membership or even Benefactor
10% Off Girling at The Bonneville Shop 2/3-2/9/23
by The Bonneville Shop - 02/03/23 6:14 pm
by Morgan aka admin - 02/04/23 2:40 pm
Buy BritBike staff a coffee ☕️ or pint 🍺
by Morgan aka admin - 01/15/23 9:29 am
Benefactor ✅
by Morgan aka admin - 01/08/23 8:38 pm
Fisherman
Fisherman
Tennessee
Lannis 84
DavidP 83
Kev. 34
DavidP 27
Uneasy Rider, Mally, Daveed, 70Triumph, Knight57Corv
12,392 Registered Users
Topics76,551
Posts784,409
Members12,392
Most Online204
Jul 10th, 2022
Looked at the newly acquired T160 parts. Someone asked about positioning of the kickstart lever, sitting angled back too far. I made a quick comparison of the two lickstart shafts and gears. From this picture you can see the notch for the cotter aligns differently, the T160 with the leading edge of the gear spline and the A75/T150 with the rear edge.
From the end view you can see the spline on the A75/T150 shaft points to the 15th whole tooth. The T160 spline points in between the 17th and 18th tooth.
The distance from the peak of the tooth to the centre of the shaft is 1.580" on the A75/T150 and 1.755" on the T160. A larger diameter gear on the T160 which means a smaller gear on the mainshaft (unless they moved the location of the kickstart, which I doubt).
The A75/T150 gear has 17 teeth, the T160 has 18 teeth.
The A75/T150 gear has 57-2169, the T160 has 57-4117 cast into it.
I think you will find it's the difference between early and later kickstart ratchet parts, not between A75/T150 and T160 (because the later T150 also had the 57-4117 quadrant) and different kickstart pinion.
http://www.tioc.org/partsbookstriumph/pb-tri-T150-1969%202nd%20ed%2099-0866.pdf
Quadrant
T2169 (57-2169)
Pinion
T2170 (57-2170)
https://www.britishmotorcycleparts.co.nz/57-2170-kickstart-pinion-22t-bsa-triumph-triples
"57-2170 Kickstart Pinion 22T - BSA Triumph
Kickstart Pinion as fitted to 4 speed BSA A75 Rocket 3 models. Also, early Triumph T150 Trident models from 1968-69."
http://www.tioc.org/partsbookstriumph/pb-tri-T150-1973%2099-0972.pdf
Quadrant
T4117 (57-4117)
Pinion
T730 (57-0730)
https://www.britishmotorcycleparts....ion-triumph?gn=Search%20Results&gp=1
"57-0730 Kickstart Pinion - Triumph
Kickstart Pinion suitable for Triumph 650cc & 750cc twins and also late Triples."
Thanks for the clarification. I put both shafts in the inner gearbox case. The leading edge of the cotter flats align pretty close although the early shaft flat was a little clockwise of the later, maybe 0.020". With the boss measuring 1.3" that comes to around 1-2 degrees if I sighted correctly down the shaft.
Novice poster
Novice poster
thanks for the info I was the OP on triples online about the kickstart lever on my t160 , I compared the angle of the cotter pin when on the stop with my rocket 3 and the t160 is about 10degrees different , the rocket 3 shaft looks shorter by about a 1/4 inch , can you confirm with your parts
thanks
thanks
The short shaft is T24(A), 57-24, 57-0024 (BSA A75 etc.).
https://www.feked.com/triumph-kicks...twins-and-t150-models-circa-1946-74.html
(Not 4 1/4" as stated)
The long shaft is T4756, 57-4756.
https://www.feked.com/triumph-kickstart-shaft-t140-tr7-and-t150-models-circa-1974-onwards.html
https://www.classicbritishspares.com/products/triumph-kickstart-shafts
https://www.ebay.co.uk/itm/223625554362
"THIS IS A GENUINE L F HARRIS TRIUMPH KICKSTART AXLE PART NUMBER 57-0024, T 0024. 4" OVERALL LENGTH, AND FITS MODELS FROM 1938 TO 1975.
SUITABLE FOR 5T 6T T110 TR6 T120 TR7 T140.
LATER MODELS USE PART NUMBER 57-4756 WHICH IS 41/4" OVERALL, SO CHECK BEFORE ORDERING"
Yup, my '72 parts book calls for 57-0024, '74 book calls for 57-4756.
I don't know what they changed, both of mine are 5-speeds. But, I do remember that my GJ '74 had a T160 kick lever on it (until it broke.)
Moderated by  Tridentman
