Topics76,551
Posts784,416
Members12,392
Most Online204 Jul 10th, 2022
Posts: 409 Likes: 18
Posts: 409 Likes: 18 |
Pre OIF, stanchion top nuts, anyone else feel the need for a washer under these? Maybe to keep from gouging new paint on the tree tops? Ditto the triple tree top nut? I've put hardware store type washers under all three and it seems ok but they're a bit wide for my taste and I thought I might find some that fit better. About 27mm ID and maybe 37mm OD and a mm thick. Any downside to having them there? I know they're not included from the factory. Thoughts?
'68 Bonnie, '70 TR6r '74 CL360 trail 70's and minitrails
Posts: 871 Likes: 100
Posts: 871 Likes: 100 |
I know Norton used washers in both locations, I'd have to check in dimensions. Don't see much chance of making ny difference fitting washers. The Norton ones are available this side of the pond in stainless, I use them on Tritons.
slofut |
Posts: 5,543 Likes: 98
Posts: 5,543 Likes: 98 |
Any downside to having them there? The steering stem nut is used for bearing adjustment so it shouldn't have, or need, a washer.
True, I was forgetting that the Norton adjustment is different.
Posts: 1,499 Likes: 37
Posts: 1,499 Likes: 37 |
I can't see any reason why the stanchion top nuts shouldn't have washers - in fact, I'm surprised they didn't have them originally, for the reason you mention (protecting the paint). But the steering head bearing adjuster nut will usually have quite a large clearance between the hex and the yoke. It needs to be able to screw to wherever the bearing adjustment is correct, so there's no point in, or need for, a washer under there.
slofut |
Posts: 2,564 Likes: 163
Posts: 2,564 Likes: 163 |
Apparently sometimes the slots in the top nut can be exposed, an avenue for water ingress to the bearings. Possibly a rubber washer or o-rings may seal this?
Posts: 8,133 Likes: 129
Born To Run
Born To Run
Posts: 8,133 Likes: 129 |
Or a good dollop of grease.
'77 T140J Silver Jubilee '82 T140LE TMA Royal ‘69 BSA Rocket 3 (patiently awaiting it's turn) "Vintage Bike". What's in your garage?
Posts: 927 Likes: 25
Posts: 927 Likes: 25 |
I always use these washers to save the paint on the top yoke. You can get them under Triumph part no 97-4166 or BSA 65-5332
1958 5TA / T100 1967 T120R 1969 TR6C 1970 TR6C
2 members like this:
Vincent Esposito, slofut |
The Norton ones were a little smaller ID and stainless so I ordered a pair to try first. Thanks everybody.
Posts: 1,654 Likes: 35
Posts: 1,654 Likes: 35 |
Slofut…..I have your Avatar on a T shirt. I know the guy who makes them. It’s the cover of Bob Dylan, Bringing it all home.
Who are the Brain Police?
68 B44 Victor 60 MGA 56 Chevy
Bob M.
Roadwarrior, you mean Dylans front album cover is this Triumph logo? I got to look that up. Not a big Dylan fan but he must have good taste in bikes.
Got the Norton stainless washers and they look like jewelry, fit perfectly but too bad you don't see them at all. At least they won't rust.
Posts: 6,111 Likes: 150
Posts: 6,111 Likes: 150 |
Both of my BSA A65s originally had washers under the fork caps (and still do). In most cases where a nut tightens against a casting, painted or not, a flat washer allows the nut to be tightened down smoothly without digging into the casting or the paint. This seems almost too obvious to mention; in any case, I can't think of any reason to NOT have a washer there.
Funny, I was here, sort of, last night with a Triumph Trophy Trail. I was adding a speedometer bracket, which on this bike is a chromed sheet metal plate which mounts under one of the fork caps. On this bike, the handlebar is right over the fork caps, and is so close to the caps that I had to remove the flat washer from under the fork cap in order to install the speedo bracket. But that's ok because the speedo bracket now serves the function of the flat washer. '
'65(lower)/'66(upper, wheels, front end, controls)/'67(seat, exhaust, fuel tank, headlamp)/'70(frame) A65 Bitsa. 2007 Triumph Bonneville Black
