Bulletin March 14th 2023
by Morgan aka admin - 03/21/23 6:58 pm
AussieDerek
AussieDerek
Wangi Wangi, NSW, Australia
DavidP 83
Lannis 68
kevin 37
John R, Commando1775, Murph, Jeff Pow, Stephen Anthony
12,439 Registered Users
Topics76,777
Posts788,039
Members12,439
lemans Offline OP
as I'm not famiiar with these bikes, having an A65 myself my question is:
the contactbreakershaft, is it the same construction as with the A65, driven of an intermediate pinion and CCW
I would like to know if the contactbreakershaft is running CW or CCW
regards Anne
No intermediate, straight off the cam. CCW
65 TR6R 68A65T 69 B44VS. 74 T150V 65 A65 D L/R
19 Chieftain
1 member likes this: lemans
lemans Offline OP
thanks, regards Anne
What's underneath there:
Happen to be working on a 69 b44
19 Chieftain
The 10mm socket you lost a couple of years back????
It’s the cam w/ gear pressed on. You can just pull it out of the cases…..what’s behind it is a bush.
Gordon Gray in NC, USA........"Trees are for traction"
That pic was my reply to the op asking if the points ran of an intermediate gear as a65's do.
Appropriately enough I was attaching the shifter to make sure I had all gears after closing that up and I needed a 10 mm. (?)
The brand new shifter had a metric bolt!
Wish I found a socket under there instead of opening my thankfully no longer much used now, metric drawer
19 Chieftain
DAMadd wrote....."That pic was my reply to the op asking if the points ran of an intermediate gear as a65's do".
Gotcha......I took it as a question....sorry, my mistake. blush
I'm in the same boat as you.......I don't open the metric drawers much anymore.....thank goodness.
lemans Offline OP
thanks for the picture because as the ccw-rotation was solved in the first answer
the second question is:
is the taper the same as for an A65?
regards Anne
I've a metric toolbox for the Alfa Romeo, Moto Morini and Moto Guzzi
and the other one to service the BSA
As the Vape electronic ignition kit seems to fit virtually all BSA and Triumph singles and twins I would guess the answer to "is the taper the same as for an A65?" is yes!
yes
lemans Offline OP
thanks again. regards Anne
