Upgrade your membership to Premium Membership or Gold Membership or even Benefactor
Triumph 650/750 High-Output Alternator Kit
by The Bonneville Shop - 01/13/23 11:29 pm
Missing edit button
by wrench136 - 05/30/22 2:57 pm
by Morgan aka admin - 01/28/23 3:01 pm
Buy BritBike staff a coffee ☕️ or pint 🍺
by Morgan aka admin - 01/15/23 9:29 am
Benefactor ✅
by Morgan aka admin - 01/08/23 8:38 pm
by Morgan aka admin - 01/03/23 6:30 pm
British Fasteners Specs
by Morgan aka admin - 01/03/23 1:29 pm
Kent Shaun
Kent Shaun
Kent Garden of England
Lannis 76
DavidP 64
Kev. 36
DavidP 25
sam keller, Raz, HermDawg, 47sqfour, Blackdoctor
12,383 Registered Users
Topics76,514
Posts783,703
Members12,383
Most Online204
Jul 10th, 2022
I have three different valve springs heights and not sure which to use. I hope the photo shows the sizes. I think the shorter spring is for a 500cc as it has less coils. The inner springs are all the same height
Parts Dealer
Parts Dealer
I honestly wouldn't play around with old springs
Get a new set of springs and call it a day
We stock Kibblewhite valve springs for the BSA A50 / A65 models
Just my 2 cents
https://www.classicbritishspares.co...hining/products/bsa-a65-valve-spring-kit
From what I can see however, the tall spring is the early spring on heads from 62-65 approx
2 members like this: pushrod tom, Bustednukel
Or at least check force at valve closed and open dimension.
The shop manuals, both early and late thru 1967 show the outer spring height as 2-1/32".
This makes sense because of the big valve head.
what is more important than free height is spring rate . The middle spring looks just off the pic to be a much heavier wire gauge and the number of turns differs from the springs show
the heavier the wire and the more turns the higher the rick of coil binding
myself i woud do with the longer one which looks to have smaller wire ... all that would differ would be the pre load
what are the wire diameters and number of turns ? ... without knowing this its all speculation
Opo Offline
A65 1962-67 outer valve spring free lenght 2 1/32"
A65 1968-72 outer valve spring free lenght 1 3/4"
Interesting.
Wire diameter was the same on all springs. Shorter springs have five coils the other two have six.
I ordered a spring pressure gage to check what I have. I’ll post what I find.
Thanks all
the strongest will be the one with less turns , funny about picture the middle one sure looks like heavier wire .
when you measure a compression spring rate you preload it a bit first , then measure how many pounds/kg over the same distance of compression ..
there are spring rate calculators online BUT you do need to know the GRADE of wire which you cant know just by looking at it ... all spring wire is not created equal ( but just for comparison doesnt matter)
let us know what you come up with
