Topics76,551
Posts784,409
Members12,392
Most Online204 Jul 10th, 2022
Posts: 6,554 Likes: 366
Posts: 6,554 Likes: 366 |
My neighbor has a 39 BSA 500 side valve....He had a wreck in 1980 and the bike has been stored since then..The front girder fork is bent but not destroyed....one down tube is kinked so at the least it will need replacement. I looked at the dust-covered bike in a dimly lit corner of his garage..The question is, are the tubes mild steel? I assume the other parts are cast steel, aka. malleable iron, brazed together? I have offered to look closely at the bike in my home shop and if possible do the repairs..
Posts: 9,280 Likes: 226
Posts: 9,280 Likes: 226 |
I do believe that the lugs are malleable cast iron, with mild steel tubes pinned and brazed into them, in a hearth.
They may not all be pinned.
Posts: 5,256 Likes: 147
Posts: 5,256 Likes: 147 |
Sounds like a worthy winter project ! How ‘bout some photos before it gets cleaned up? 👀
Down to ‘69 T120R now a Tr6R tribute bike ‘70 TR6C “happy in the hills” ‘67 A65LA (now single carb) ‘93 K1100RS heavy metal (should be gone, still here…)
Posts: 2,132 Likes: 37
Posts: 2,132 Likes: 37 |
https://jakerobbinsvintageengineering.co.uk/girderforkrepairI don’t know if he would know, but jake robbins is a UK girder expert who might be able to answer an email? Obviously you’re not going to send a set of forks across the pond.
Posts: 5,467 Likes: 274
Posts: 5,467 Likes: 274 |
The lower fittings for the axels are forged The mid fittings joining the tubes can be either forged steel or cast malleable iron AFAIK BSA always furnace braised all tubing Tubing is plain carbon but it is tapered
Bike Beesa Trevor
Hillbilly bike |
