Topics76,551
Posts784,409
Members12,392
Most Online204 Jul 10th, 2022
Posts: 8,155 Likes: 354
Posts: 8,155 Likes: 354 |
I'm replacing the ugly old header on my '72 T150V. The Triple Tec header I bought looks beautiful, if only I could get it mounted. The center pipe takes a bit of struggle to line up, and the pipe rubs on the frame down tube. In any case I can't get the pipes any closer than 1/4" away from the head. I took a file to the adapters to clean them up, no use. I bought new adapters, though I was only able to replace two of them. The RH one will not turn and I don't wish to chance striping the threads. Still no joy, the thing simply will not go fully on the adapters. At least the old header used three separate head pipes. Has anyone used this exhaust system? Are there any secrets to how to get the darn thing on?
Posts: 1,491 Likes: 54
Posts: 1,491 Likes: 54 |
I've found that most 'new' pipes have to be massaged. Use a towel type rag or rope wrapped around the pipe several times and pull and tug till the system bends enough to fit. Once you get it on and ride it, the heat generally 'sets' the system and it fits from then on. Try to avoid rubber mallets etc Sometimes with the system off the bike, you then use a slightly smaller piece of pipe inside the headers and use this to tweak the alignment.
Once you have the headers on and bolted up, you can then use the bike to bend the side exhausts to your preferred position. Again you may need to use the smaller length of pipe to help bend them. To avoid dents and kinks etc, position the smaller pipe in as far as it will go and exert some pressure, then reposition the smaller pipe out a but the exert pressure again, then position the smaller pipe out a bit again and repeat. This way you are bending along the length rather than in one place. I bought a Viking big bore system and had to do all of the above to get it to fit. But now I can unbolt and re install with no such issues.
Posts: 220 Likes: 35
Slow and old
Slow and old
Posts: 220 Likes: 35 |
The awful - looking headers on my T150 are what I believe to be a stock set welded together. Still able to install/remove, but the oil cooler must first be removed.
I left the pipes in place overnight. Perhaps the metal relaxed a bit, I got the outer two as close as 1/8", but the center pipe is still about 1/4" away. I don't know how I could hold the assembly firmly enough to tweek one pipe. My vice would likely mar the finish. And here I thought that I gave up having to modify parts to fit when I sold my BSA.
pidjones |
trick is to get one in place and bolt it up. Then paly with the others one at a time.
pdjones, the Viking big bore kit is also a one piece, I also have to remove the oil cooler every time I want to remove it. But for a top end rebuild, I just let it hang there secured by a couple of occy straps.
At least I can do this system with the cooler in place. Just have to figure out how to route the cables to the instruments. I didn't notice at first, but the Triple Tec picture of their system mounted on a '71 has no tach cable on the engine. Worst case I'll need a T160 speedo cable and swap sides for the instruments.
Slow and old
Slow and old
I can just take the tach cable loose from the drive and leave it to dangle.
Posts: 300 Likes: 8
Posts: 300 Likes: 8 |
Lowes has a nice selection of small clamps that the ends are plastic coated. I use them to fret a MAC 4 into one header on a cb750 that was driving me crazy. Check them out.
Posts: 371 Likes: 36
Posts: 371 Likes: 36 |
Haven't fitted the exhaust on the t150 project so can't help there yet, but I have a question. All my spigots are loose ( probably removed for the head work) my thought was never seize (copperslip)and tighten fairly tight with a large screwdriver thru the hole-no torque spec I can find but it's steel into aluminum- that sound about right?
Dave 65 TR6R 68A65T 69 B44VS. 74 T150V 65 A65 D L/R 19 Chieftain
Posts: 6,338 Likes: 629
Posts: 6,338 Likes: 629 |
You have the right idea. Suggest first of all try the spigots dry into the head and feel for the fit. If it is loose then I think oversize spigots are still available. Once you are happy with the fit then proceed as you suggest. I have never seen a torque spec for that but really tight is what I do (just short of BFT-- Bloody F*****g Tight).. Back in the day if the fit was a bit sloppy then the dodge was to slightly distort the spigot by squeezing it in a vice but that was in the days when we had no money (so what has changed?-- Brit humor). HTH
Posts: 88 Likes: 14
Posts: 88 Likes: 14 |
"my thought was never seize (copperslip)and tighten fairly tight with a large screwdriver thru the hole"
Not likely to get tight enough without the screwdriver bending.
Sorce a 3/4 drive socket that fits neatly over the spigot, drill a hole the same size as the one through the spigot at a suitable length along the socket.
The socket can then be secured with a high tensile bolt through the holes, you will then have another service tool in your box of things you'll only ever use once.
Posts: 5,608 Likes: 224
Posts: 5,608 Likes: 224 |
I went the other way using an internal deep well 7/8" socket ![[Linked Image from live.staticflickr.com]](https://live.staticflickr.com/65535/52458133861_cac9fbf41f_z.jpg) The cross pin is 5/16". The tool on the left is for my SpinRing exhausts which do not require hammering the pipes on and off.
I got the pipes on as far as I could. The outer two are fully in place, the center is still about 1/8" out. Of course, the holes in the adapter line up with the slots in the pipe, I'll need to check for leakage. Maybe if I run the engine for a while I can put on my welder's gloves and shove it further on? Now I've found that the megaphone won't go on the collector far enough to fit the mounting bolt at the rear hanger. The only solution I see is to cut about 1/2" off the end of the collector. For $1000 I expected better!
That's a lot of cash! Sorry for the thread jack just seemed relevant. My 3 into 1 came off this bike supposedly, and the center stand was in the parts bin. About to give a go at installing it.
None of the pipes have an obvious position and I had hoped the relation to the collector would help but it very not-intuitive. Maybe you got couple switched
This system has the three pipes welded into the collector as one assembly, not possible to switch pipes. I prefer the three separate head pipes of my old system, much easier to remove and install. I suppose that I could have filled and finished the dents in the pipes and had the whole thing done with CeramiKote, or just wrapped the head pipes like so many bobbers, or just go back to stock if I thought I could find a manifold which was made well. This exhaust came highly recommended by a few folks on the TR3OC Facebook page. As it stands I'm about 1/2-3/4" away from getting the rear mount lined up with the exhaust hanger. That part on a '74 is different, maybe it goes back further to account for the cigar mufflers? But, without one for comparison I have no way of knowing.
Posts: 300 Likes: 8
Have you brought the situation up with the maker???
Posts: 1,988 Likes: 109
Posts: 1,988 Likes: 109 |
I'd take it back to the vendor as being unsuitable. If they refused a refund I'd insert it so they walked like John Wayne
I'd take it back to the vendor as being unsuitable. If they refused a refund I'd insert it so they walked like John Wayne It cost $150 postage to get it here from California. In any case, after a bit of careful work with a file inside the muffler I was able to get it on. I'll leave it bolted up overnight before I tighten the clamp. It will be fine after a few heat cycles.
2 members like this:
pidjones, tridentt150v |
Now I guess I have to have the bike painted.
pidjones |
Posts: 300 Likes: 8
Looks good man even keeps the center stand. Paint what????
Looks good man even keeps the center stand. Paint what???? The tank is original 50-year old paint with many nicks. The side covers are supposed to be the same color. I have the correct decals for the covers, but I'm not putting them on black covers.
I took it out for a spin today. It runs well and pulls strong. WOT shows no sign of 8-stroking, but it burbles a bit when I close the throttle. The old header liked 170 mains, I just ordered some 160. It wails like a proper banshee, but now I know that the tach is lying to me. No way in hell that engine is spinning at 8500 rpm.
