Topics76,758
Posts787,766
Members12,432
Most Online230 Mar 11th, 2023
Posts: 9,042 Likes: 314
Posts: 9,042 Likes: 314 |
Hey Guys, Gary hasn't asked the question yet, but it has been mentioned before. On an A65 with the 3-hose oil manifold, is it okay to add the filter to the oil tank return line and leave the small line connected straight to the rocker arm infeed? Other than circulating "unfiltered" oil are there any other issues? Thanks, Doug That caused my '71 to empty the oil tank into the sump. Took about 10 miles, YMMV Ran like that for 15 years, its never caused me any problems, perhaps it was a bad filter or a one way filter piped up the wrong way? If you have a sump cover with magnetic drain bolt fitted and it is a "strong" magnet and too close to the pickup, this can cause wet sumping. Doug, unless your shells are falling apart and passing metal fragments through the pump then the centrafugal filter (sludge trap) will have removed most of the crud, id be surprised if anything bad made its way to the rockers.
Now lets all have a beer!
Posts: 8,274 Likes: 379
Posts: 8,274 Likes: 379 |
Hey Guys, Gary hasn't asked the question yet, but it has been mentioned before. On an A65 with the 3-hose oil manifold, is it okay to add the filter to the oil tank return line and leave the small line connected straight to the rocker arm infeed? Other than circulating "unfiltered" oil are there any other issues? Thanks, Doug When I added a Norton filter adapter to my '71 A65 I blanked off the small pipe on the manifold and added a T connector in the return line to feed the rockers. I can't say how it would have performed had I used the original feed pipe.
do it twice Gary |
Posts: 62 Likes: 8
Posts: 62 Likes: 8 |
DavidP, good point! To filter the low percentage of oil going to the rockers, a tee after the filter and before returning to tank might be the solution. Regardless, any filtration when using detergent oils is going to extend the life of the notorious timing side bushing. Gary
67 BSA A65L, 67T120R, 71 Hodaka 100B, 72 HD Aermacchi 350SS "cafe racer" 60 HD Duoglide, 77 HD FLH, 79 HD FXEF, 12 HD FLHTC
Posts: 2,844 Likes: 36
#irideslow
#irideslow
Posts: 2,844 Likes: 36 |
Hey Guys, Gary hasn't asked the question yet, but it has been mentioned before. On an A65 with the 3-hose oil manifold, is it okay to add the filter to the oil tank return line and leave the small line connected straight to the rocker arm infeed? Other than circulating "unfiltered" oil are there any other issues? Thanks, Doug That caused my '71 to empty the oil tank into the sump. Took about 10 miles, YMMV ... perhaps it was a bad filter or a one way filter piped up the wrong way? If you have a sump cover with magnetic drain bolt fitted and it is a "strong" magnet and too close to the pickup, this can cause wet sumping. ... Thanks, but no, none of that. Blocking the rocker feed at the oil junction pipe and fitting a T after the filter fixed the wet sumping. There was a long discussion here a few years ago when I was building the bike. As I said, your experience may differ.
Kurt
- Don't believe everything you think.
Posts: 6,133 Likes: 157
Posts: 6,133 Likes: 157 |
Mark, What's the overall length of the filter? Do you think the map filter will fit into the toolbox, with maybe a little modifying? Nice installation. Gary Sorry, I've been away from the forum for a while. I believe the filter would fit in the tool carrier, but you would have to cut out the lower end of the carrier for the fuel lines. I would have tried that but I've never had a tool carrier for this bike. In case I didn't mention this above, the MAP filter takes the same elements as Rocket 3's and Tridents.
'65(lower)/'66(upper, wheels, front end, controls)/'67(seat, exhaust, fuel tank, headlamp)/'70(frame) A65 Bitsa. 2007 Triumph Bonneville Black
Posts: 12 Likes: 1
Posts: 12 Likes: 1 |
Hey Guys, Gary hasn't asked the question yet, but it has been mentioned before. On an A65 with the 3-hose oil manifold, is it okay to add the filter to the oil tank return line and leave the small line connected straight to the rocker arm infeed? Other than circulating "unfiltered" oil are there any other issues? Thanks, Doug That caused my '71 to empty the oil tank into the sump. Took about 10 miles, YMMV Why would that happen? Dave
Returning to the road....
#irideslow
#irideslow
Hey Guys, Gary hasn't asked the question yet, but it has been mentioned before. On an A65 with the 3-hose oil manifold, is it okay to add the filter to the oil tank return line and leave the small line connected straight to the rocker arm infeed? Other than circulating "unfiltered" oil are there any other issues? Thanks, Doug That caused my '71 to empty the oil tank into the sump. Took about 10 miles, YMMV Why would that happen? Dave To my benighted brain, the oil was taking the path of least resistance, feeding an excessive quantity of oil to the rockers, which then drained into the sump ... and vicious cycle.
Kurt
Posts: 5,310 Likes: 154
Posts: 5,310 Likes: 154 |
Kurt,…. “ … To my benighted brain, the oil was taking the path of least resistance, feeding an excessive quantity of oil to the rockers, which then drained into the sump ... and vicious cycle.”. That would be correct, and that is the reason to be sure the filter is a FullFlow, Read: easy to blow through, filter. The Emgo filter works OK on my ‘67, and I have tested others and used them also when not ordering Emgo.
Down to ‘69 T120R now a Tr6R tribute bike ‘70 TR6C “happy in the hills” ‘67 A65LA (now single carb) ‘93 K1100RS heavy metal (should be gone, still here…)
2 members like this:
Allan G, do it twice Gary |
Posts: 219 Likes: 2
Posts: 219 Likes: 2 |
This begs the question for me of the best place in the oil circuit to place a third party filter. I was planning on putting it on the oil outlet from the tank, so that all oil that reaches the engine goes through it. That places it before the pump, and I can see some logic in having it in the higher pressure post-pump location. Where is the best place to put it?
- Mark
Posts: 167 Likes: 32
Posts: 167 Likes: 32 |
DO NOT PUT THE FILTER IN THE FEED LINE! DO PUT IT IN THE RETURN LINE! If there is a problem with the filter your engine won't be toast if it's in the return line. The oil will get plenty of filtering in the return line.
Allan G |
On my OIF Bonneville I use the MAP filter. It hides nicely behind the TS rear engine mount plate. I must remove the side cover to replace the filter element. I also own a Trident, so both use the same filters.  A full flow filter, but on the Triumph the rocker feed is after the filter anyway.
Posts: 219 Likes: 2
Posts: 5,674 Likes: 236
Posts: 5,674 Likes: 236 |
All the abrasive bits are made in the engine so the return line will get them before they settle in your oil tank. Of course if you do not clean your oil tank after putting the filter on any debris in the tank can still go through the engine before it gets caught in the filter. There are remote filters with two outlets, one for the tank the other for the rockers with the correct size pipes.
……………. There are remote filters with two outlets, one for the tank the other for the rockers with the correct size pipes. Interesting, Have never seen one of those.
Posts: 62 Likes: 8
Since I purchased one of these "Norton" style add on filter assemblies, I started looking to cross reference full flow filters that are readily available at the local parts stores. I only come up with the non-stock variety like the Champion COF103101S. There should be more than a couple filters that will work. Maybe I'm not searching correctly. Gary
Posts: 90 Likes: 1
Posts: 90 Likes: 1 |
"There are adapters (Colorado Norton Works sells one) that you screw onto the filter base, converting it to a regular 3/4"X16 thread, which gives all kinds of options for filters.
Mike
My company car is a Kenworth
do it twice Gary |
Wix sells a filter made for Simca or Citreon 2cv cars with the correct thread. I used to be able to buy those at the O'Reilly main store in Nashville. I can't remember the Wix number, but usually what was in the box was labeled Mann Filter W712/9.
do it twice Gary |
Posts: 12 Likes: 1
……………. There are remote filters with two outlets, one for the tank the other for the rockers with the correct size pipes. Interesting, Have never seen one of those. remote filter headYou can remove the blanking plugs and fit connection fittings. They come in many colours.
Posts: 6,562 Likes: 369
In remembrance
In remembrance
Posts: 6,562 Likes: 369 |
On the several "Norton" type filter heads I have bought in the last few years take a K&N or Hiflo #153. This is a common Ducati filter easlily found online or in some auto parts stores
do it twice Gary |
Since I purchased one of these "Norton" style add on filter assemblies, I started looking to cross reference full flow filters that are readily available at the local parts stores. I only come up with the non-stock variety like the Champion COF103101S. There should be more than a couple filters that will work. Maybe I'm not searching correctly. Gary I have used this Champion filter, the WIX W7101 filter and the Bosch filter, as mentioned my bikes (and others who I ride with) have the filter on the return side and without disturbing the return line and never had a problem. Filters should be free flowing, the rocker feed should have some pressure behind it, if there isn't then something isn't right. Though what KC said makes a lot of sense, if your filter isn't free flowing then this could cause problems
do it twice Gary |
Posts: 12 Likes: 1
OK.... given that the rocker feed on A65 is a smaller diameter than the tank return....would this work ok? ![[Linked Image from i.ibb.co]](https://i.ibb.co/cQj398d/IMG-20221031-134055.jpg) Dave
OK.... given that the rocker feed on A65 is a smaller diameter than the tank return....would this work ok? Dave Sorry Dave, I just use the full flow filter and no other plumbing or mechanical flow restrictor adjustments, and it’s been working OK for me. Again, the Emgo filter is available and works. I’ve cut them open to inspect, and there is stuff caught in the paper. So as far as I can see, even at Full Flow, it’s worth the effort and doing some good. Thanks for the link to that mount option, I see the web has so much stuff! The one shown is quite large and looks to be for a full size spin on filter, which isn’t desirable for Brit bikes. The Norton adapter works, and the Emgo filters work. Easy Peesy…
That remote filter head uses AN-10 which is equivalent to 5/8". Filter head can be machined for different number and pipe arrangements ![[Linked Image from live.staticflickr.com]](https://live.staticflickr.com/65535/52468070736_a7c3f909c4_z.jpg) HF116 filter used on H*nda, Husqvarna, Polaris ![[Linked Image from live.staticflickr.com]](https://live.staticflickr.com/4568/24729325608_5da7657754_o.jpg)
Posts: 6,196 Likes: 315
Posts: 6,196 Likes: 315 |
For the Norton type spin on, Borg and Beck BFO4180 fits, easy to find on ebay.
