Bulletin March 14th 2023
by Morgan aka admin - 03/21/23 6:58 pm
BeezaBryan
BeezaBryan
Derbyshire UK
DavidP 82
Lannis 68
kevin 37
John R, Commando1775, Murph, Jeff Pow, Stephen Anthony
12,439 Registered Users
Topics76,776
Posts788,036
Members12,439
Anyone have any pictures or better description of where these add on oil filters can be located? Some adds say behind transmission? Thanks, Gary
67 BSA A65L, 67T120R, 71 Hodaka 100B, 72 HD Aermacchi 350SS "cafe racer" 60 HD Duoglide, 77 HD FLH, 79 HD FXEF, 12 HD FLHTC
I made a mount shaped like a piece of C channel, but welded together to be the correct dimension and attached it with the bolt on the rear motor mount. I used a Norton type filter adapter. The filter is somewhat protected by the centerstand. I had to pull the rear fender and the oil lines (which needed to be modified anyway to plumb in the filter) to get the bolt out and the mount and adapter on. Sorry I don't have any photos right now, but the bike (69 Thunderbolt) is a bit deep in the garage and I am tending to my wife who just had surgery. Hope this helps.
DJinCA
AML Offline
Since I lack fabrication skill and am lazy by nature, I bought a filter mounting kit from Paul Goff in the UK.
http://www.norbsa02.freeuk.com/goffyoil.htm
Put one from MAP cycle on my 70 Tbolt. Mounts to the rear foot peg mount and uses a Trident filter.
http://www.mapcycle.com/categories/...-map-universal-oil-filter-kit-black.html
Here's my solution for the MAP oil filter. That is a steel plate with two L-brackets that bolt to the tool carrier mounting lugs. A P-clamp holts the filter. You can remove the one P-clamp bolt in order to tip the filter outward to change the element. One little snag was that the spigots on the filter are 3/8", and my hoses are 5/16", so I had to source some "reducing fittings".
2007 Triumph Bonneville Black
2 members like this: Psychopasta, do it twice Gary
Mark, What's the overall length of the filter? Do you think the map filter will fit into the toolbox, with maybe a little modifying? Nice installation. Gary
I wish I had a picture of how I installed it on my 70 Tbolt but the bike's been sold. All I did was remove the nut holding the timing side rear footpeg, slip the clamp supplied with the kit on and replace the nut. The body of the filter is parallel with the swing arm with the hose bosses to the front. Took all of about 5 minutes.
i once mounted one on a T120 on the right side behind the gearbox, bolted to one of the motor mount bolts. all the hoses were behind the plate
and other stuff
A common way using the "Norton" filter adpter.
One thing to be aware of, the early and later oil manifolds on the bottom of the motor have different size tubes. Fussing to match with the filter hose size.
A65 Filter mount3.JPG A65 filter mount1.JPG A65 Oil Fltr mount from RH side.JPG A65 Oil Fltr mount from LH side.JPG A65 Filter mount2.JPG
‘70 TR6C “happy in the hills”
‘67 A65LA (now single carb)
1 member likes this: do it twice Gary
KC, that looks like a good installation, but a bit LOW.
Would a skid plate be necessary to protect it?
Don’t have a handy photo, but its above the center stand when stowed. I may be at the bike today for a pic.
Another alternative:
A few different pipe locations and sizes available including 5/16".
I like the Morgo filter, it is nice and slim and fits between the engine plates on a pre unit
[Linked Image from live.staticflickr.com]20160321_122720_zpsl8dpzkwz by Sigma Projects, on Flickr
GM500 sprint bike "Deofol"
Rickman Jawa 500 "Llareggub"
Yamaha RD250B
Kawasaki Ninja H2 "Fujin"
ANY oil filter is better than NO oil filter.
I keep looking an some of the small ones on some lawn mowers, ones like the Kawasaki vertical crank engines use.
Those are plentiful (NAPA stores stock them) but some type of mount would need to be made.
But that's my project for a later date.
1 member likes this: kevin
“ But that's my project for a later date.” A65 or Triumph ?
A021AF58-3E5A-4C34-8B9F-03C42FC38E3B.jpeg 2C6B6839-B74D-4949-9D7E-24A84A739DA1.jpeg CC20B2FA-905A-40D7-B9A5-5150792436FD.jpeg
In my case, TRIUMPH.
But with the oil-feed system the BSA twins use, an oil filter is essential to keep grit in the oil from wearing the crank's oil feed busing.
Wow! some great looking pics! The only thing better would be to have it installed for me. But that wouldn't be any fun. Thanks for all the responses! Gary
Originally Posted by Irish Swede
In my case, TRIUMPH……………..
Will PM you with a thought……. Gotta find the photos, but was posted on the board previous,….. if you are better at the search than Me!
On A TR6C........
PMd you if you haven’t noticed…………. 👀
K.C.:
THAT, sir, is a VERY SLICK installation. It harms nothing, and uses two already existing frame mounting lugs.
By mounting the filter sideways, it guarantees there is plenty of clearance.
I presume the aluminum part was hand-made on a lathe, but what is the origin of the filter itself?
None the less, it has given me a new idea of how to do it.
i bought thisfull-flow remote mount off eBay for US$18, added some hose barbs and a four dollar muffler clamp. some nylocs. clamps around the frame spine tube, but could be put anywhere using the holes in the mount. takes an ordinary auto supply store filter. an inexpensive solution.
the advantage of a vertical filter is that you can prime it with oil prior to screwing it on.
and other stuff
Hey Guys,
Gary hasn't asked the question yet, but it has been mentioned before. On an A65 with the 3-hose oil manifold, is it okay to add the filter to the oil tank return line and leave the small line connected straight to the rocker arm infeed? Other than circulating "unfiltered" oil are there any other issues?
Doug
#irideslow
#irideslow
Originally Posted by Doug P
Hey Guys,
Doug
That caused my '71 to empty the oil tank into the sump. Took about 10 miles, YMMV
Kurt
- Don't believe everything you think.
I have always used a Full Flow filter, one that I can blow through fairly easy, no red face!! If the filter is too hard to pass oil, the “back up” can cause the rocker feed to take the “excess”. I guess that would be different on the 2 types of oil manifolds, but my ‘67 has the feed off the motor manifold, not off the tank. The Emgo filters are good for the flow purpose, but others are also, …… looks kinda weird in the auto parts store, back there blowing in filters……. 🤓
Hey Guys,
Doug
, I have a filter on my 71 A65, the rocker feed at the manifold is capped shut, new rocker feed tees off return line between the filter and the tank.
Moderated by  Jon W. Whitley
