Topics76,551
Posts784,416
Members12,392
Most Online204 Jul 10th, 2022
Posts: 47 Likes: 3
Posts: 47 Likes: 3 |
Anyone have any pictures or better description of where these add on oil filters can be located? Some adds say behind transmission? Thanks, Gary
67 BSA A65L, 67T120R, 71 Hodaka 100B, 72 HD Aermacchi 350SS "cafe racer" 60 HD Duoglide, 77 HD FLH, 79 HD FXEF, 12 HD FLHTC
Posts: 189 Likes: 25
Posts: 189 Likes: 25 |
I made a mount shaped like a piece of C channel, but welded together to be the correct dimension and attached it with the bolt on the rear motor mount. I used a Norton type filter adapter. The filter is somewhat protected by the centerstand. I had to pull the rear fender and the oil lines (which needed to be modified anyway to plumb in the filter) to get the bolt out and the mount and adapter on. Sorry I don't have any photos right now, but the bike (69 Thunderbolt) is a bit deep in the garage and I am tending to my wife who just had surgery. Hope this helps.
DJinCA
Posts: 326 Likes: 8
Posts: 326 Likes: 8 |
Since I lack fabrication skill and am lazy by nature, I bought a filter mounting kit from Paul Goff in the UK. http://www.norbsa02.freeuk.com/goffyoil.htm
Posts: 6,111 Likes: 150
Posts: 6,111 Likes: 150 |
Here's my solution for the MAP oil filter. That is a steel plate with two L-brackets that bolt to the tool carrier mounting lugs. A P-clamp holts the filter. You can remove the one P-clamp bolt in order to tip the filter outward to change the element. One little snag was that the spigots on the filter are 3/8", and my hoses are 5/16", so I had to source some "reducing fittings". ![[Linked Image from i.postimg.cc]](https://i.postimg.cc/wBZyPK2H/GEDC1963.jpg)
'65(lower)/'66(upper, wheels, front end, controls)/'67(seat, exhaust, fuel tank, headlamp)/'70(frame) A65 Bitsa. 2007 Triumph Bonneville Black
2 members like this:
Psychopasta, do it twice Gary |
Posts: 47 Likes: 3
Mark, What's the overall length of the filter? Do you think the map filter will fit into the toolbox, with maybe a little modifying? Nice installation. Gary
Posts: 163 Likes: 32
Posts: 163 Likes: 32 |
I wish I had a picture of how I installed it on my 70 Tbolt but the bike's been sold. All I did was remove the nut holding the timing side rear footpeg, slip the clamp supplied with the kit on and replace the nut. The body of the filter is parallel with the swing arm with the hose bosses to the front. Took all of about 5 minutes.
Posts: 6,627 Likes: 332
Posts: 6,627 Likes: 332 |
i once mounted one on a T120 on the right side behind the gearbox, bolted to one of the motor mount bolts. all the hoses were behind the plate
Posts: 5,256 Likes: 148
Posts: 5,256 Likes: 148 |
A common way using the "Norton" filter adpter. One thing to be aware of, the early and later oil manifolds on the bottom of the motor have different size tubes. Fussing to match with the filter hose size.
Down to ‘69 T120R now a Tr6R tribute bike ‘70 TR6C “happy in the hills” ‘67 A65LA (now single carb) ‘93 K1100RS heavy metal (should be gone, still here…)
do it twice Gary |
Posts: 4,981 Likes: 230
Posts: 4,981 Likes: 230 |
KC, that looks like a good installation, but a bit LOW. Would a skid plate be necessary to protect it?
Don’t have a handy photo, but its above the center stand when stowed. I may be at the bike today for a pic.
Posts: 5,608 Likes: 224
Posts: 5,608 Likes: 224 |
Another alternative: ![[Linked Image from live.staticflickr.com]](https://live.staticflickr.com/65535/50382351823_22928d5735_z.jpg) ![[Linked Image from live.staticflickr.com]](https://live.staticflickr.com/4568/24729325608_5da7657754_o.jpg) A few different pipe locations and sizes available including 5/16".
Posts: 1,988 Likes: 109
Posts: 1,988 Likes: 109 |
I like the Morgo filter, it is nice and slim and fits between the engine plates on a pre unit 20160321_122720_zpsl8dpzkwz by Sigma Projects, on Flickr
ANY oil filter is better than NO oil filter. I keep looking an some of the small ones on some lawn mowers, ones like the Kawasaki vertical crank engines use. Those are plentiful (NAPA stores stock them) but some type of mount would need to be made.
But that's my project for a later date.
kevin |
“ But that's my project for a later date.” A65 or Triumph ?
In my case, TRIUMPH.
But with the oil-feed system the BSA twins use, an oil filter is essential to keep grit in the oil from wearing the crank's oil feed busing.
Posts: 47 Likes: 3
Wow! some great looking pics! The only thing better would be to have it installed for me. But that wouldn't be any fun. Thanks for all the responses! Gary
In my case, TRIUMPH…………….. Will PM you with a thought……. Gotta find the photos, but was posted on the board previous,….. if you are better at the search than Me! On A TR6C........
Wow! some great looking pics! The only thing better would be to have it installed for me. But that wouldn't be any fun. Thanks for all the responses! Gary PMd you if you haven’t noticed…………. 👀
K.C.:
THAT, sir, is a VERY SLICK installation. It harms nothing, and uses two already existing frame mounting lugs. By mounting the filter sideways, it guarantees there is plenty of clearance.
I presume the aluminum part was hand-made on a lathe, but what is the origin of the filter itself?
None the less, it has given me a new idea of how to do it.
Posts: 32 Likes: 2
Posts: 32 Likes: 2 |
Hey Guys, Gary hasn't asked the question yet, but it has been mentioned before. On an A65 with the 3-hose oil manifold, is it okay to add the filter to the oil tank return line and leave the small line connected straight to the rocker arm infeed? Other than circulating "unfiltered" oil are there any other issues? Thanks, Doug
do it twice Gary |
Posts: 2,844 Likes: 36
#irideslow
#irideslow
Posts: 2,844 Likes: 36 |
Hey Guys, Gary hasn't asked the question yet, but it has been mentioned before. On an A65 with the 3-hose oil manifold, is it okay to add the filter to the oil tank return line and leave the small line connected straight to the rocker arm infeed? Other than circulating "unfiltered" oil are there any other issues? Thanks, Doug That caused my '71 to empty the oil tank into the sump. Took about 10 miles, YMMV
Kurt
- Don't believe everything you think.
I have always used a Full Flow filter, one that I can blow through fairly easy, no red face!! If the filter is too hard to pass oil, the “back up” can cause the rocker feed to take the “excess”. I guess that would be different on the 2 types of oil manifolds, but my ‘67 has the feed off the motor manifold, not off the tank. The Emgo filters are good for the flow purpose, but others are also, …… looks kinda weird in the auto parts store, back there blowing in filters……. 🤓
Posts: 6,178 Likes: 302
Posts: 6,178 Likes: 302 |
Hey Guys, Gary hasn't asked the question yet, but it has been mentioned before. On an A65 with the 3-hose oil manifold, is it okay to add the filter to the oil tank return line and leave the small line connected straight to the rocker arm infeed? Other than circulating "unfiltered" oil are there any other issues? Thanks, Doug , I have a filter on my 71 A65, the rocker feed at the manifold is capped shut, new rocker feed tees off return line between the filter and the tank.
do it twice Gary |
