Trying to trouble shoot why a 74 T150 won't start. It backfires and pops but won't run. With fully charged
battery 13 volts, when connected with a voltmeter to the white feed and ground it only measures 11.1 volts. Box was drawing over 3 amps.
Boyer said this is to be expected with 3 four volt coils in series and the triple box.
However, doing the same test with a Norton
Commando was only drawing 0.2 amps.
Boyer said this was normal for the twin box as it only sees full current for a second or two.
I seem to recall that the
Boyer Box on twins doesn't turn itself on until the crank rotates to save the
battery from running down. Does the triple box not have this feature?
