Topics76,551
Posts784,416
Members12,392
Most Online204 Jul 10th, 2022
Posts: 47 Likes: 3
Posts: 47 Likes: 3 |
I'm trying to educate myself on these BSA's until my eyes cross looking at the laptop. I picked up a fragment that 67 BSA's had the same issue with the 4ca points plate and the advance unit that Triumph had. Looking in my boxes of parts I see the advance is marked 11 degrees. I thought my 67 T120 was marked 12 degrees and found the 12 for the Triumph was OK. Is the BSA 11 degree the "OK " unit? Thanks, Gary
67 BSA A65L, 67T120R, 71 Hodaka 100B, 72 HD Aermacchi 350SS "cafe racer" 60 HD Duoglide, 77 HD FLH, 79 HD FXEF, 12 HD FLHTC
Posts: 6,111 Likes: 150
Posts: 6,111 Likes: 150 |
'67 BSAs still had the 4CA advance unit and breaker plate, so if yours is original that's what it has.
The 4CA breaker plate is easily identifiable; there are no "sub-plates" to adjust timing each set of points individually, and the condensers are mounted on the breaker plate. The advance unit is more difficult to identify, but the dwell cam profile changed, so it must be upgraded along with the breaker plate.
If you need to upgrade to the 6CA setup, you'll probably wind up spending more for the parts than it would cost to install an electronic ignition.
'65(lower)/'66(upper, wheels, front end, controls)/'67(seat, exhaust, fuel tank, headlamp)/'70(frame) A65 Bitsa. 2007 Triumph Bonneville Black
Posts: 4,438 Likes: 30
Posts: 4,438 Likes: 30 |
I kept the 4CA plate and used a later cam. The later cam is taller when viewed from the side so is easy to identify. A BSA one advances anti clockwise.
Posts: 6,178 Likes: 302
Posts: 6,178 Likes: 302 |
If you like doing things twice then the 4CA plate comes with many advantages, not only is it fiddly to set up with accurate timing but it comes with the hidden bonus of poor cam design which creates rogue sparks, this greatly improves the chances of blowing up the engine allowing you to rebuild at your inconvenience at some point in the future. Another great feature for the tinkerer that comes with the 4CA are the internal condensers/ capacitors, these suffer from heat and fail quickly compared to externally mounted caps, and being part of the points plate construction they are hard to substitute with other caps .And lets not forget the points heel which rubs on the cam, subtle but so good for wear necessitating continuous monitoring of points gap closure and slowly drifting ignition timing great for roadside repairs, because unlike EI you can and will have to repair at the side of the road. You can have even more fun tinkering with a badly sealed points chamber , oil ingress from the seal guarantees the need to clean and regap at regular intervals. Your fellow riders will truly appreciate an old school , hard core dedicated 4CA user , as they chat at the side of the road while the user performs its quaint repairs.
3 members like this:
NickL, Shane in Oz, kevin |
You can have even more fun tinkering with a badly sealed points chamber , oil ingress from the seal guarantees the need to clean and regap at regular intervals. Just to complement your statement gavin, note that the EI trigger mechanism cares not if there's a little oil present (which is commonly the case). And yes, this is another good reason to convert.
Posts: 1,372 Likes: 489
Posts: 1,372 Likes: 489 |
............You can have even more fun tinkering with a badly sealed points chamber , oil ingress from the seal ......... All Gavin's droll comments are absolutely spot on. But, just to take this train of ideas for one more go round, the bushings on that hard working idler gear are known for wearing badly. On an old engine, this virtually guarantees oil leakage from the seal onto your points, AND, you get the additional aggravation of your ignition timing wandering as the load on that gear varies with rpm. I've seen it with my own eyes. .......Just to complement your statement gavin, note that the EI trigger mechanism cares not if there's a little oil present ....... Also true. But, here's a little known EI failure mode that I'm not quite sure I believe, at least not yet. On two recent desert rides, an EI trigger on a 750 Triumph quit sparking due to an alleged accumulation of magnetic dust on the working parts. Both times, hosing the points cavity out with gasoline or blowing it out with air got the thing running again. Anybody else have any thoughts on this? I mean, besides hollering BS.
gavin eisler |
Posts: 4,023 Likes: 329
Posts: 4,023 Likes: 329 |
alleged accumulation of magnetic dust sometimes the rotor does not seat deeply enough in the taper check the running clearance between the rotor magnets and the 2 tangs that protrude from the bottom of the stator plate . cant say off hand what the min running clearance should be , maybe 0.5mm ? ![[Linked Image from feked.com]](https://www.feked.com/images/detailed/154/IMG_9250-1000_d6oz-kt.jpg)
alleged accumulation of magnetic dust ..check the running clearance between the rotor magnets and the 2 tangs....... That was my first thought too but when I asked, the guys had already looked and found no wear marks to indicate contact was happening.
Posts: 47 Likes: 3
Thanks for all the comments, even if they didn't answer the original question. I enjoy reading the fragments of information here from experienced BSA owners and always learn something from them. Sometimes I fail, learn from it, then hopefully succeed. Hence the "do it twice" name I gave myself. I did find some info else ware on this site concerning the rogue spark problem with 67 A65L's advance units. Similar to the 67 Triumph issue that was solved by the factory after a given DU number. BSA did this and updated the advance unit if your motor serial # ends with a dash Y. If true, and since mine does and I can only assume its original, I'm probably OK unless there's a way to identify the advance unit. This might be true. Thanks, Gary
the BSA is least worst.
Thanks for all the comments, even if they didn't answer the original question. I enjoy reading the fragments of information...... You're quite welcome. It is all part of the Special High Intensity Training we get to go through so we can enjoy our British bikes. Sounds like you are beginning to get a handle on it. On the auto advance unit, the early style lobe is recognizable basically as a circle with a flat spot that holds the points open for around 300 degrees, the later lobe is reduced to approximately 180 degrees that the points are held open. Someone hopefully has some photos to post. The AA part number is 54419344 it is a 12 degree and advances counter clockwise. Nortons use this one too. The points plate number is 54419097 You should be able to google those numbers and see what the parts look like.
do it twice Gary |
............You can have even more fun tinkering with a badly sealed points chamber , oil ingress from the seal ......... All Gavin's droll comments are absolutely spot on. But, just to take this train of ideas for one more go round, the bushings on that hard working idler gear are known for wearing badly. On an old engine, this virtually guarantees oil leakage from the seal onto your points, AND, you get the additional aggravation of your ignition timing wandering as the load on that gear varies with rpm. I've seen it with my own eyes.. Note here that the Triumph setup is not as bad as BSA, since on a Triumph the AAU runs off the exhaust camshaft, which is more stable than the BSA idler pinion. I say this because some Beezers may have had previous experience with Triumphs and may feel that the breaker point ignition is "not that bad". I'm probably OK unless there's a way to identify the advance unit. This might be true. Thanks, Gary Correct me if I'm wrong Stuart, gavin, but I'm under the impression that the breaker assembly was changed at the same time as the AAU, to where there are sub-plates to allow for timing each set of points individually, and the condensers are moved from the breaker plate to under the seat.
I'm probably OK unless there's a way to identify the advance unit. there are ways . the 67 came as a complete 4CA Advance unit . ( condensers on the points plate and 86 deg points cam ) ... but the 4CA points plate ( top ) is mixable with the later 6CA points cam .( bottom ) The 4CA Points cam ( bottom ) has 86° of dwell . this cam is a round-ish shape .... with one flat of 86 degrees ( some people call it a D-shape ) ... ( I don't know that this is always associated with 11° advance ) ... so I would look at the cam-shape and not the Advance-stamp that the cam is attached to thiis 86 deg. cam is what caused all the problems ... when run at 12 volts anyway ...for the first time in 1967 ( the same cam was used for at least 3 years before , by BSA and Triumph and others , from 63 to 66 at 6 volts , without problems , )... I believe this same cam profile was also used in 18d2 distributors ( so used back as far as the mid 1950s ) At some time, mid-to-late in 67 , or maybe it was early 68 . bsa offered ... just the 6CA 160° points cam ( bottom half ) As a warranty fix for the problems with the 86° cam ... so for 67 ... it's fully possible that the Factory , a BSA dealer or a home mechanic added the longer dwell 160° cam to the earlier points plate . (top ) 160° of dwell makes the 6CA cam ... look more like an egg with 2 tips ( the closing ramp looks almost as sharp as the opening ramp ) by 1968 ... Lucas was making and selling the full 6CA top and bottom as a unit ... for new builds ... but you didn't get the 6ca top ( the points plate ) as part of a BSA warranty claim for bikes that we're already fitted with the 4CA unit ( 67 ) ... you got only half of the improved part .... ( a kit with just the later cam and some kind of shim washer to better align the points arm ) None of this addresses the fiddliness of the 4CA points plate (top) ... which works if you know the process And are willing to deal with it But if you're just getting familiar with the 4CA points ... make sure you look at the bottom cam ... because it could be 4CA or 6 CA
do it twice Gary |
Posts: 8,991 Likes: 305
Posts: 8,991 Likes: 305 |
On BSA service sheets the 4ca cam was identified by having the 11 degree advance, and 6ca as having the 12 degree advance.
Now lets all have a beer!
do it twice Gary |
Posts: 47 Likes: 3
Thanks for the explanation. My 11-degree advance has the shorter duration profile so I believe I'm ok with it. gary
Gary, unless I missed it, you still didn't say which breaker assembly you have.
I was digging through a junk box looking for something else and found these two, one old, one newer. The one on the left is the one that gives trouble, the other one is the improved one. ![[Linked Image from i.postimg.cc]](https://i.postimg.cc/vTtMXYtP/IMG_20221015_164023553.jpg) Notice also that the early style is also shorter. Hope this helps. ![[Linked Image from i.postimg.cc]](https://i.postimg.cc/ry18qj2S/IMG_20221015_164127807.jpg) (They aren't both the same rotation btw but it doesn't matter for what we're doing.)
