15% Off Black Friday Sale
Spitfire Ken
Spitfire Ken
Illinois
kevin 55
Bry 24
12,333 Registered Users
4 members (Magnetoman, Jon W. Whitley, HayMike, Madmotorman), 12 guests, and 27 robots.
Topics76,682
Posts782,987
Members12,333
Most Online204
Jul 10th, 2022
Page 2 of 2 1 2
Originally Posted by Rokplo
…..snip…..
I also heard of valve getting a little bit stuck in the guide when cold, and become free with heat, because of a bit of dirt stuck somewhere ....
It was along time ago but I had a Commando that would run like a pig until it warmed up……then was fine. I have no recollection of how I found out what the problem was but it turned out to be weak ( not broken) valve springs. Swapped out for new and the problem went away.
Just trying to help
Gordon Gray in NC, USA........White man broke the code
Rokplo Offline OP
…..snip…..
Just trying to help
Thanx, i'll have a look if i have to open the rockers cover ....
See my pics on my instagram RokploPhotos
Someone had to have told me about that being a possible problem…..honestly I wouldn’t have known to look at/check them.
I think it was one of those things where I actually got the new springs first figuring new springs wouldn’t be a bad idea.
The bike would start but REALLY stumble until warmed up then it ran okay.
I only paid $325 for it so it got a lot of worn out stuff replaced.
Good luck……keep at it, you’ll sort it
This may have been covered disregard if it has.
How’s the carb slide, ever been sleeved.
Not sure if you checked vacuum leaks. I use WD 40 sprayed around the flange. If it revs you got a leak, be carful.
How’s the plugs looking on a cold run, before it smooths out. ie: crappy running may be lean do to sloppy slides or vacuum leak.
Rokplo Offline OP
Slide seems ok, il check for air leaks, i ordered a set of new seals and gaskets, i'll renew it all to be sure
Carb clean, brake clean or easy start would show an increase in revs when sprayed around a leaking flange. WD40 isn’t very combustible and usually causes engine revs to falter.
Have you felt the exhausts like I mentioned earlier?
Sometimes it is hard to tell if a problem is on both cylinders or just one.
You may not feel any difference, but if you do then you can eliminate a load of common factors, like carb, ignition etc.
Probably need two people.
Just spent a length of time messing with a Chinese copy of a 1990s Honda. Previous hackers had installed new carbs plus a ton of stuff, missing the fact it wasn't firing with any gusto if at all on one pot! Still haven't fixed the problem (and probably won't) but at least I know what it is!
Rokplo Offline OP
This morning, before going to work, i checked valve clearance. Left inlet valve had not enough clearance (0.10 mm instead fo 20). My carb is in pieces, waiting for new gaskets and seals, so i couldn't try yet. Hope it's only that ....
I'll receive my compression tester today, so i'll check compressions tonight
Rokplo Offline OP
I finally rebuilt the (cleaned) carb with the old gaskets .... exactly the same thing, no change at all .... i also put (again) new spark plugs, and checked it after 3 mn reving up : perfectly clean as new, no gas wet or oil on it
Rokplo Offline OP
Just mesured compressions : 7bars/100 psi in each side, coherent with the 7.25 :1 compression ratio ... still thinking it’s a carb problem ...
Quoting the WSM, "7.5:1 CR, Comp pressure, both plugs out, throttle open, warm motor, first kick 65-70, Average, 120 -125 psi.
If readings obtained are substantially below those quoted, the engine is need of attention to valves, and piston rings or may even require a rebore"
Rokplo Offline OP
I did mesurements on cold engine, first kick was 100 ....
at 0.004" inlet clearance it will run like a pig until doing a high RPM. I tried tightening up my inlet valve clearances by a couple of thou once upon a time. completely altered how the bike ran, and it wasn't very tractable compared to standard settings.
Simple easy way to eliminate the possible wiring / connections. Attach a jumper direct from battery to the Boyer, try running. Then do the same with the other “side”, try running. (Not sure if you are set up + or - to frame)
BTW, This is how I found the loose lug rivet on the IGN switch was my issue. (Only jiggled when running)
‘70 TR6C “happy in the hills”
‘67 A65L numbers match, “best effort” from basket *
Gone:
‘66 A65L“in ‘95 getting back in the game”+ empty ‘67 Case&Frame *
‘69 A65L
‘68 A65L “red bike” basket, sold & made whole by BB member
‘68 A65F nice Tribute bike
‘65 A50L bitsa from spare parts, Son’s fun
‘62 A10 Spitfire
‘65 T120R sad case, saved by BB member
'65 XLCH “scratched THAT itch”……
Rokplo Offline OP
Yes, good idea, i'll make a very simplified wiring with just Boyer, battery and coils, it will eliminate the electrical possibility (or confirm ?)
Page 2 of 2 1 2
