by C.B.S - 09/22/22 5:28 pm
gREgg-K
gREgg-K
Ottawa, Canada
kevin 112
DavidP 68
reverb 29
kevin 25
Fritzilo, Fishbreath, Oilysock, Pacho, Abtinnmant150
12,264 Registered Users
4 members (TinkererToo, Al Eckstadt, Mark Z, Hillbilly bike), 15 guests, and 25 robots.
Topics76,353
Posts778,255
Members12,264
Most Online204
Jul 10th, 2022
#891480 09/22/22 11:16 am
W
wind1 Offline OP
W
Hi All-
My 76 T140 kickstart axel has movement sliding horizontally in towards and back from the gearbox. What I am gathering is that this sometimes prevents the quadrant from meshing with the pinion gear on the mainshaft.
Is it normal for the shaft to do this - its about 1/2 an inch. Checked the ratchet and pinion and all are in good repair. Something is amiss, but I'm not sure what.
Any suggestions?
Cheers.
That which doesn't kill us...
76 T140V
72 R75/5
73 Norton
Normal would be a few thousandths of an inch, not 1/2 an inch.
From the description, it sounds as if the kickstart quadrant could be loose on the axle splines.
W
wind1 Offline OP
W
Thanks L.A.B.-
The quadrant is solidly on the shaft. I tried tapping the quadrant tighter on the shaft with a socket and hammer to take up any space where it could move but it was solidly in place. I thought at first there was a missing spacer, but none is shown in the parts book.
76 T140V
72 R75/5
73 Norton
I don't know what else could be causing the 1/2" of play then. Because as you said, there shouldn't be a spacer.
the kickstart arm w/cotter .. holds the quadrant axle "in place" ... to the outer cover
and when installed
the quadrant is captured between the inside of the outer cover ( outer bush ) ... and outside of inner cover ,
With enough room to freely rotate , but nowhere near 1/2 an inch .
The spring can drop off the peg so the assembly still has to be held fully out until the spring has been pre-tensioned (by one full turn of the lever) before the cover is replaced.
and when installed
It will be axle spring locating splines "...between the inside of the outer cover (outer bush)" not the "quadrant" (because the spring is outboard of the quadrant).
Moderated by  Jon W. Whitley
