by C.B.S - 09/22/22 5:28 pm
Dave Comeau
Dave Comeau
Hamilton, Mass. USA
kevin 115
DavidP 60
kevin 30
reverb 29
12,261 Registered Users
7 members (crabby15, pidjones, Gordon Gray, Andy Higham, mr.moto, Opo, TR7RVMan), 18 guests, and 23 robots.
Topics76,325
Posts777,860
Members12,261
Most Online204
Jul 10th, 2022
#891478 09/22/22 10:45 am
I want to install a set of sidecar rated fork springs in my Golden Flash forks, but I'm confused. This is a description of some heavy duty sidecar springs advertised on Ebay....
"BSA A10 A50 A65 fork springs.
Heavy duty for use with sidecars
External type.
OEM part number 42-5145.
Newly manufactured in England . Excellent quality.
Approx 11 3/4" long, 1 7/8" outside diameter, 1 7/16" inside diameter.
Sold in pairs."
What are External type fork springs ? If there are external type springs, then it stands to reason that there must also be internal type springs.
Which type do I need for my bike ?
I identify as being fully vaccinated.
"External" fork springs go around the OUTSIDE of the fork stanchions. Typical of BSA forks.
"Internal" fork springs go INSIDE the fork stanchions, as typical of Triumph forks, 1945-1963.
2 members like this: kommando, Gordon Gray
You want external springs, the Draganfly website has the spring details for the BSA heavy duty forks fitted to A10 through to A65.
Thanks. I will order external ones. smile
For sidecar use it was normal to lower the gearing by using an 18T engine sprocket compared with the standard 21T sprocket for the A190.
The 18T sprocket used to be readily available as it was the standard engine sprocket for the A7 500 cc bike.
I'm not sure what sprocket I have in it now, I will see how it performs.
I do have a spare 20 tooth sprocket.
The real question here is: are you gonna use them (springs and therefore the bike) with or without sidecar?
Harold / Motolab.nl
BSA: W35-11 (sloper) ‘35, WM20 '40 M21,B31 '54 B33 '55 ZB34GS '49, DBD34GS '58, DBD34GS ‘60
Triumph 5T '49 + T100 + speedkit
Moto Guzzi LeMans '79
BMW R51/3 '51, R100GS '89
With.
They have the details but not the springs.
Thanks NickL
