Topics76,809
Posts788,573
Members12,449
Most Online230 Mar 11th, 2023
Posts: 195 Likes: 40
Posts: 195 Likes: 40 |
Went for a ride on my 1969 441 Victor Special a few days ago. Man, I love that bike! I ran into a guy that started badmouthing BSA singles when he saw mine, about how they were hard to start, etc. He was on a Ducati. I tried to explain that my 441 VS almost always started on the first or second kick. He challenged me with a $20 bet that it would not start on either the first or second kick. The bike had been sitting for about 4+ hours and was completely cold. I accepted the challenge. He laughed and thanked me in advance for the twenty bucks. I was very careful to go through my starting procedure exactly. He actually threw the $20 at me and left without a word when it fired up on the first kick and idled perfectly. Several watchers started cheering.
Current Bike: 1968 Triumph Bonneville T120R, 1969 BSA Victor Special, 1975 Norton 850 Commando John Player, M1030M1 U.S.M.C. Diesel Previous British Bikes: 1968 BSA Lightning, 1969 BSA Lightning, 1969 BSA Firebird Scrambler, 1972 BSA B50 Gold Star, 1974 Triumph Trident Previous Non-British Bikes: 1983 BMW R80RT
6 members like this:
Mitch, Gary E, Allan G, Gordon Gray, SpeedyV, D.Bachtel |
Posts: 6,725 Likes: 378
Posts: 6,725 Likes: 378 |
okay
what exactly is your starting procedure?
ive heard at least a dozen, and my 69 441 doesnt like any of them.
and other stuff
okay what exactly is your starting procedure? ive heard at least a dozen, and my 69 441 doesnt like any of them. Kevin, This is what I do. Cold Starting 1. Tickle the carburetor until you see gas while the bike is vertical and not on side stand 2. Pull compression release and use kick starter to turn the engine over 5 - 6 times 3. Bring the engine up to compression and pull the compression release and then bring the engine slightly past compression 4. Bring kick starter up to top and then kick it over while the bike is vertical. Do not hold the throttle open while kicking over - leave it closed. Hot Starting 1. Don't tickle the carburetor 2. Steps 3 - 4 as above. I've found that it is very easy to flood the engine during hot starting. If my engine is hot and recently shut down, I never tickle the carb. It virtually always starts on the first kick when hot just by turning the key on and doing nothing but kicking. If I tickle the carb when the engine is hot, I end up looking for a hill to roll down because my leg gave out! I also know that every motorcycle is different and just because my starting procedure works with my 441 VS, doesn't mean it will work the same for someone else. Gary
Gary E |
having just got a long neglected A65 on the road, my nearly as long neglected victor is next.
i will use your technique and return with my confessions
and other stuff
Posts: 3,662 Likes: 72
Posts: 3,662 Likes: 72 |
Gary: Great $$ story. My son Rick and I put some time in on a couple of 69 Victors and starting was really never an issue. They were set up with only the Lucas blue capacitor and no battery. Rick had no experience with a Brit single before the Victor but caught on very quickly. I agree that the technique is important. Gordo
Posts: 312 Likes: 57
Posts: 312 Likes: 57 |
I actively hold my throttles closed when starting. While technique is paramount, setup is critical as well. I suspect British Singles got a bad rep from young first timers buying clapped out (cheap!) bikes with worn out leaky carbs and cruddy points / capacitors (Jo Lucas was not known as the Prince of Darkness for nothing!). Just like I did 50 years ago!
Posts: 37 Likes: 8
Posts: 37 Likes: 8 |
I find that setting a slightly higher idle while cold starting then dropping the idle when the bike is warm helps. With the idle set for a low enough tickover i find that the bike will fire but won't catch and run. other than that what i do is very similar to the proceddure mentioned earlier and it usually starts first or second kick.
1971 BSA A65T 1968 BSA B44
Posts: 1,651 Likes: 113
Posts: 1,651 Likes: 113 |
Yes, Sam...and the knurled knob on the idle screw makes it much more convenient. Assuming you got it running, when you shut it off it is probably idling fairly low so turning it up a little works. If something goes wrong, like flooding, you'll probably have to start from scratch. Clear cylinder, find the correct slide height, etc.
69 A65T 71 B50T 85 K100RS 54/59 A10SR 69 B44VS 71 A65FS 95 Trident Too much moderation is bad for you.
Posts: 2,049 Likes: 85
Posts: 2,049 Likes: 85 |
Good on ya Gary
the way i see it is any man who bad mouths another mans bike is a dork!
My friend who is a bike wrecker describes Ducati as " top dollar for scrap alloy" , he doesn't carry parts for them and doesn't even wreck them
PS he isnt being a dork because by the time he sees them they have either exploded or been in a smash
Posts: 6,140 Likes: 158
Posts: 6,140 Likes: 158 |
...the way i see it is any man who bad mouths another mans bike is a dork! Got to give him credit though for putting his money where his mouth is.
'65(lower)/'66(upper, wheels, front end, controls)/'67(seat, exhaust, fuel tank, headlamp)/'70(frame) A65 Bitsa. 2007 Triumph Bonneville Black
Posts: 14,946 Likes: 510
Posts: 14,946 Likes: 510 |
...the way i see it is any man who bad mouths another mans bike is a dork! Got to give him credit though for putting his money where his mouth is. That's the way I see it. It's one thing to just be a rivet counter or anorak or big-talker. It's another to lay down money on your opinion and win it or lose it. Takes one out of the realm of "Anorak" and into "Sporting Cove", which is OK by me .... !! Lannis
Patriotism is supporting your country all of the time and your government when it deserves it.
fair comment guys however :
OP stated " He actually threw the $20 at me and left without a word when it fired up on the first kick and idled perfectly. "
doesn't exactly sound gracious in defeat does he ... RUDE *&%#*&er if you ask me
doesn't exactly sound gracious in defeat does he ... RUDE *&%#*&er if you ask me No argument there.
