Topics76,551
Posts784,416
Members12,392
Most Online204 Jul 10th, 2022
Posts: 4,438 Likes: 30
Posts: 4,438 Likes: 30 |
Is JASO MA-2 oil less likely to cause clutch slipping than the normal api sf 20 or 30 oil or is it just better than car oil? Dave
Posts: 2,409 Likes: 450
Posts: 2,409 Likes: 450 |
With separate primary setups, most blokes prefer auto transmission fluid, the old type. Jaso would be fine but more expensive as to whether it would be any better, i'm sure there are views both ways.
Posts: 8,155 Likes: 354
Posts: 8,155 Likes: 354 |
Mine shares oil and I use a JASO MA-2 oil, Valvoline synthetic motorcycle 20W50. It works fine with the clutch. I think the key is the lack of friction modifiers, as found in car oil. I guess if I had an older separate primary I might try transmission oil, but type F is getting hard to find and expensive here.
Posts: 8,991 Likes: 305
Posts: 8,991 Likes: 305 |
Which bike is it?
I find running in oil works great in clutches. Though if it’s a 3 spring triumph/bsa clutch then you’ll want to make sure that the clutch itself is upto spec with the correct springs otherwise they don’t hold/grip too well, regardless of the oil used.
Now lets all have a beer!
Thanks for the replies. The bike is my 67 Triumph 650. The clutch is marginal but ok. I have discussed changing it on here but never got round to it as it works ok. I am mostly wondering if JASO MA-2 is an improvement over the 60s spec 20 oil rather than car oil. I suppose I should just try it!
Posts: 5,256 Likes: 148
Posts: 5,256 Likes: 148 |
I’ve always wondered if the focus is the chain lube or the clutch? I tried transmission fluid twice, leaks can’t really see an advantage, went back to the book 20wt. In one bike, auto transmission fluid turned the rubber parts gooey!
Down to ‘69 T120R now a Tr6R tribute bike ‘70 TR6C “happy in the hills” ‘67 A65LA (now single carb) ‘93 K1100RS heavy metal (should be gone, still here…)
2 members like this:
Allan G, kevin |
Posts: 2,093 Likes: 329
Posts: 2,093 Likes: 329 |
My preference would be to try and match the oil that the manufacturer originally recommended with whats available these days. From what I can understand based on info at This Website, the original JASO MA-1 spec was introduced in 1998 and the JASO MA-2 spec in 2006. Its worth reading the different JASO specs carefully, and from what I can make out JASO MA-1 spec is suitable for bikes with separate engine and gearbox oils. JASO MA-2 is for bikes with catalytic converters. The website mentions that JASO MA-2 oils have a higher friction modifier content than JASO MA-1 oils, so on that basis I would stick with the JASO MA-1 oil. Personally, I just use classic 20w50 classic car oil in both engine and clutch without issue, my current favorite is Motul classic 20W50 which has a high zinc content and works fine in the engine and primary see This Link.
NickL |
Posts: 5,467 Likes: 274
Posts: 5,467 Likes: 274 |
On the bikes with closed primaries I run ATF in them simply because it is pink. The gearbox oil is green & of course engine oil becomes black very quickly os mystery drips can be identifed easily
Bike Beesa Trevor
Posts: 6,111 Likes: 150
Posts: 6,111 Likes: 150 |
When I used motor oil in the primary on my A65, after one or two riding seasons I would get a cooked-on oil residue on my clutch discs, which would cause the clutch to both slip AND stick on sitting. I would then scrub the discs with kerosene, and they would be ok for a month or so, but would then revert to slipping and sticking, and the only solution was to replace the discs. Then I started using ATF (type F), and no more cooked-on oil residue; in fact, I can't remember when I last replaced clutch discs. I've also noticed the clutch runs cooler, for instance, if I have to idle in gear for more than a few seconds.
If there's a flip side to this coin, it would be that the more viscous oil is better for the primary chain. I have no data to support that assertion one way or the other.
'65(lower)/'66(upper, wheels, front end, controls)/'67(seat, exhaust, fuel tank, headlamp)/'70(frame) A65 Bitsa. 2007 Triumph Bonneville Black
Thanks. It seems that the JASO MA-2 oil is the same as the originally specified oil in regard to clutch action. For some reason I have also had the idea that atf is not so good for the chain as pondered on by Mark Z. I don't know where I got this idea from because no one has ever said that their chain has worn out because of it.
Apparently type F as used by some Fords is a problem
Bike Beesa Trevor
Posts: 9,280 Likes: 226
Posts: 9,280 Likes: 226 |
Apparently type F as used by some Fords is a problem Type F is the one I most often see recommended.
Gordon Gray |
Posts: 1,988 Likes: 109
Posts: 1,988 Likes: 109 |
If you think about what goes on in an automatic transmission. Gears and bearings that need to be lubricated and clutches that need to transmit drive. Substitute chain for gears and it's not very far from a primary drive
Apparently type F as used by some Fords is a problem OLD Fords. Even my '97 Ford van uses Dextron. I used to use type F in my forks. These days proper fork oil is easy to find and probably cheaper. I honestly can't say if it makes any difference in the primary, I've only had shared oil bikes, and the dry clutch in my Trident doesn't care.
Posts: 47 Likes: 3
Posts: 47 Likes: 3 |
Just read this and since it's a month I'll chime in anyway. It is my understanding that type F was designed for auto transmissions that had "band' style clutches (the old ford -o- matic) and type A is meant for multi-plate clutches (old hydra-matic) It was and old hot rod trick to use type F in trannys designed for type A to have less slippage and positive engagement... Gary
67 BSA A65L, 67T120R, 71 Hodaka 100B, 72 HD Aermacchi 350SS "cafe racer" 60 HD Duoglide, 77 HD FLH, 79 HD FXEF, 12 HD FLHTC
Posts: 6,628 Likes: 332
Posts: 6,628 Likes: 332 |
type F fixed the on-off clutch in my Commando. had some other ATF in there, and the clutch was so grabby it stalled the bike.
