by C.B.S - 09/22/22 5:28 pm
Tridentman
Tridentman
kevin 115
DavidP 60
kevin 30
reverb 29
12,261 Registered Users
8 members (tridentdude75, Stuart Kirk, gavin eisler, sbk99, Gordo in Comox, quinten, tridentt150v, NickL), 14 guests, and 21 robots.
Topics76,325
Posts777,860
Members12,261
Most Online204
Jul 10th, 2022
I have recently become the proud owned of a 90 % restored A10 Golden Flash, all the mechanical work has been done.
Although it's not originaL, I quite like the look of it how it is. It came with a leaky Indian tank, the paint had been bubbling from the seams on both sides since it was sprayed back in 2015.
I peeled the paint off to see what was going on and discovered a tiny spot on both sides where fumes have been leaking, there was no signs of actual wet fuel leaking. It looks like the fumes lifted the paint.
The tank is very heavy and substantial, I think it's a good tank, they just tidied up the welded seams a bit too much.
I have priced out getting the tank chromed,( $1000 just for the chrome ) and then getting it painted somewhere else, but there is nowhere local that will do the chrome plating, so shipping is another expense. I can get the tank painted with two colours just a three hours drive away, and I think that can look classier than chrome....
Something like this, but change the green with black.
I think this is how it would have looked originally but I don't like it.
It's $600 CAN for a silver and black paint job, or $300 for plain black.
Please help me make up my mind. smile
I identify as being fully vaccinated.
OP "I quite like the look of it how it is."
Me too!
1 member likes this: Pureblood
It looks like I will not do better than to get another tank from India. I found a seller on ebay with 100% rating who can supply specials for less than half the price of anything around here.
This is what I will order.
Make sure you test for leaks BEFORE doing anything with a new tank. ?
The better suppliers supposedly test for leaks - with a 2 psi pressure test.
I recently acquired a couple of Enfield tanks.
And intend to line them before putting them into service.
The welding and joints seem OK - but better to be safe than leaky !!
Petrol spitting off a hot exhaust could spoil your day ...
I take it you're ordering an A10 swingarm tank and not a plunger frame type as they mount differently.
Just a few Beezers..
1. DO NOT PAY TO BUY AN INDIAN MADE
2. IF YOU MISTAKENLY BUY AN INDIAN-MADE TANK DO ADD TO THE MISTAKE BUY SPENDING MORE MONEY TRYING TO FIX IT.
IN YOUR CASE YOU ALREADY HAVE AN INDIAN-MADE TANK PUT PUT YOUR MONEY INTO TRYING TO FIX IT SO IT DOES NOT LEAK. DO NOT TO T DO NOT PUT AN EXPENSIVE CHROME JOB OR PAINT JOB ON IT UNTIL YOU HAVE USED IT FOR A TIME AND ARE CONVINCED IT WILL NOT LEAD AGAIN. MANY ANKS FROM INDIA ARE MADE FROM SUCH A POOR GRADE OF STEEL THAT I HAVE LITTLE TO NO FAITH IN THEM.
The Devil is in the details.
2001 Kawasaki W650
I have never done it but know plenty of guys who have.
they get their tank stripped ONLY by an electro plater then when the inside is chemically clean put in a liner., seems to work.
obviously you would attend to any apparent leaks first
original paint pattern is always best but tank chroming is an expensive job ... i would go with silver paint replacing chrome personally.
I have your bike but in plunger ,,, great old heaps.
Capslock !
I type one handed all the time.
Beer or coffee time in the other ....
Good point about plunger or swingarm type tanks.
i dont use the shift key either.
never seemed to hurt me any
From my experience I would say Indian made tanks are fine, as long as you are prepared to fix them. It all depends on availability, and how much money you have to spend. Sometimes it's an Indian made tank or bugger all.
I have had the old tank welded and it's not leaking now, I'm going to get it silver painted, but it's going to be a while before the bloke who I trust can do the job can do. In the meantime I will be using another tank I bought from India.
Compared to modern bikes it is a bit of a heap, but that's partly why I like it. smile
My stock line to young whipper snappers who laugh at my old &hit box is .... " fine SONNY bring your plastic wizz bang back in 70 years and we will try a 1/4 mile !
at least everything on our old dungas is designed to be fixed eh .
Of the above photos, my favorite is the silver (chrome?) and black with the gold outline and red tank badge.
2007 Triumph Bonneville Black
2 members like this: Pureblood, Mark Parker
Does anyone know where I can find small screws to fit plastic tank badges ?. smile
Probably any of the vendors on this site will have them.
Gordon Gray in NC, USA........"STOP blaming the bike!!!!”
I was thinking of the likes of a hardware store, rather than bother people ordering something not worth anyones while. That said, I have found a set that I altered to do the job..
There are two studs on the front of both my tanks that look like they should be bolted to something, do you have any idea what ?
It looks like the studs that are used for a cross strap that stops the tank from flexing. It is listed as 42-8091 Petrol tank stiffening plate in the Gold Star parts books.
Not a lot of people know that !
Thanks Gordo
A few thoughts on this Indian tank..........
It looks really good, but it's not perfect. It is considerably smaller than the original Indian tank that came with the bike. I asked the seller about the size discrepancy, and recieved this reply.....
"this particular tank model is made by diecasting. Which means these are machine pressed and 100% copy of the original. The bottom part of the tank (fitting) is used in various BSA models like A7 A10, Goldstar, etc. This is the reason there is a huge demand and for this particular model we have invested in diecasting for quick production and delivery."
It came with badge screws that were way too big, and were Phillips cross head screws, not the original slot head type. I used them but only after a lot of fiddly work..
The threaded holes for the gas taps are on the piss, and there is nothng I can do to fix it.
It's probably the best that's available, and I would buy another fom the same source.
someone told you:
"this particular tank model is made by diecasting. ......" ....RUBBISH die casting is where molten metal is cast in a die typically alloy....
he probably meant pressing where sheet steel is formed using a press tool
someone told you:
He is obviously comfused, but he says they are machine pressed and a 100% copy of the originals. I am inclined to believe that.
We are lucky people still make the effort to produce these, I would be lost without them.
So far it holds petroleum without leaking. smile
Thanks Gordo
Those who d0 not know will find out sooner or ltter wne the tank splits by the seat nose and they end up with chemical petrol burns on their private parts .
someone told you:
I doubt that unless some one has sent the indian company a tank to make a copy from (like Gordon Grey did) then they would ever seek a tank to copy from. They sure as damn cant get the coach work correct so getting the tank forming correct is going to be tricky. I have also seen many an pre unit tank which is nothing like the original when placed side by side. My father has a "goldstar" tank that came with a frame, tank doesn't look bad but it looks big enough to have ate another tank or two before it could fit on the shelf.
someone told you:
There were lot's of English bikes exported to India over the years. Getting an original a10 bsa tank to copy would be very easy.
Getting a set of decent knee pads complete with slot head screws seems more problematic than getting a decent tank. I have given up altogether, and have ordered stick on knee pads.
Guy I know sent a pre-war Panther tank to India to be copied ,,,AND he actually got it back with the new one.
Seems to me that all Indian tank makers are not created equal... some are very good , some are rubbish and everything in between,
so how to find a good one?
