Bulletin March 14th 2023
by Morgan aka admin - 03/21/23 6:58 pm
BeezaBryan
BeezaBryan
Derbyshire UK
DavidP 83
Lannis 68
kevin 37
John R, Commando1775, Murph, Jeff Pow, Stephen Anthony
12,439 Registered Users
Topics76,777
Posts788,039
Members12,439
Page 2 of 2 1 2
I didn't check it a few days ago and during a ride within 100 yards she slowed, clattered, and seized up
To me, it sounds like most of the oil has been lost during the last two rides (80 miles?) but the question is where did all the oil go without being noticed?
Since the bike appears to be leak-free and no pool of oil was noticed on the floor after the last ride, I can only think of two possibilities, both related to the sump filling with oil whilst riding:-
- check the silencers for a black oily look inside and also the top of the pistons and cylinder head for black oily deposits.
- have a look at the breather pipe exit and the area around it, is there evidence of oil contamination?
If either of the above is true then it may suggest that the oil was burning off and blue smoke would have been seen in the exhaust. Oil may also have been spurting out of the breather.
Unless you had someone riding behind you, you would not be aware of the situation, until the engine seized.
I would check the scavenge side for any blockages which might cause the sump to fill.
Triumphs on eBay
Hi , Sorry, USA mechanics often call big end shells inserts. Short for rod bearing insert.
In remembrance
In remembrance
Or just " bearuns"...... Ya run that motor will no "all" and them bearuns'll burn up...
3 members like this: tridentt150v, Gordon Gray, Tigernuts
I've been set back a bit now as some cretins broke into my garage and nicked my Velocette MAC and BSA SS and various tools and the new bits for the Triumph repair.
Good info from Don. How easy is it to weight match conrods if they are billet aluminium? I still have one perfect...
Chris
Wait Chris, you're saying your Velocette and a bsa were stolen? And new parts?
'68 Bonnie, '70 TR6r
'74 CL360
trail 70's and minitrails
I wonder if your oil light was flashing during the last ride?
Hi, First year for oil pressure light was 1969.
Some call these idiot lights. That is not correct. They are warning lights that give valuable information to rider.
Is a high beam indicator, or turn signal indicator light for idiots?
Problem is with the oil light, is hard to see in bright sunlight.
I’d wager if the 67 had oil light this damage likely would not have occurred. Is gauge better? Only if you look at it. Often warning light catches your eye sooner.
Page 2 of 2 1 2
