by C.B.S - 09/22/22 5:28 pm
Tridentman
Tridentman
kevin 115
DavidP 60
kevin 30
reverb 29
12,261 Registered Users
11 members (trevinoz, chaterlea25, koan58, BikeVice, sbk99, Steve Erickson, mr.moto, Magnetoman, charlie akey, htown70, Xavier Devars), 10 guests, and 22 robots.
Topics76,325
Posts777,860
Members12,261
Most Online204
Jul 10th, 2022
Page 2 of 3 1 2 3
E
E
When I put my '66 Spitfire together, I used the original tank. It didn't take long for the ethanol to start doing its thing. I ordered Caswells and followed the directions, which included using the supplied solvent first (I think it was MEK, but I don't remember). I let it dry out for a couple of weeks after using the solvent. I then followed the directions about pouring in the liner and periodically changing the position of the tank to ensure full coverage. I then took out the plugs I had put in the petcock holes and drained out the excess. The first thing that drained out was more solvent (even though shaking the tank after putting in the solvent and letting it dry hadn't revealed any solvent left in the tank)! Recognizing that this wasn't a good sign I went to a local fiberglass guru (who sadly has since disappeared) who had previously been with NASA as a composites engineer. His view was that sloshing sealer about and hoping for full coverage was more than a bit hit or miss. He also felt that because of the differing coefficients of expansion of the sealer and the fiberglass tank, thick applications were doomed to eventually separate from the tank. He cut the bottom of my tank off along the seam with a utility knife, cleaned up the inside, roughed it up and painted the insides with Caswell using a brush in order to make the coating as thin as possible, but achieving full coverage. He then glued the bottom back together with fiberglass and used tubing and a syringe to put Caswells along the seams. His price was reasonable ($200) and included touching up the paint on the bottom where he had cut it. I used the tank for a couple of years without any problems. Then the powers that be jacked up the amount of ethanol in gas and I decided to investigate Indian metal tanks. I bought an unpainted one and the original tank went on the shelf. The Indian tank looks pretty original, but it is not exact. The center hole for the mount was slightly off, so I had to make an adapter. The petcock holes were sized for Triumph petcocks (which I prefer any how). It does not have indentations for the decals. It looks great and from 10 feet you can't tell the difference.
You’d remember if it was MEK, it sends you loopy from the fumes.
…. So I’m told 🤪
I have always utilized Acetone to prep the the inside of the glass tanks. It is far more quick drying than MEK. Evaporates within minutes. Not that Acetone is human friendly, but MEK is far worse. I quit using it very early on in my fiberglass construction decades ago.
In terms of epoxy resin quantity, more is not better. It only adds weight and reduces interior volume, and is more prone to cracking. In the standard glass tank, 1/2 or less of the Caswell kit is utilized to seal the interior. I mix 1/2 of the kit, and still pour out some excess.
Hi Gary,….. Not to HyJack this thread, but do you leave gas in your bikes or drain them for expected periods of non-riding?
‘70 TR6C “happy in the hills”
‘67 A65L numbers match, “best effort” from basket *
Gone:
‘66 A65L“in ‘95 getting back in the game”+ empty ‘67 Case&Frame *
‘69 A65L
‘68 A65L “red bike” basket, sold & made whole by BB member
‘68 A65F nice Tribute bike
‘65 A50L bitsa from spare parts, Son’s fun
‘62 A10 Spitfire
‘65 T120R sad case, saved by BB member
'65 XLCH “scratched THAT itch”……
I drain all of the British bike tanks...and then the petcock corks dry out. I also start the rides with clear preminum or avgas, but always drain the tanks no matter what fuel is left in them after the ride.
Solved the cork leak/dry issue on a couple pairs of Ewarts for me.
1970 T120R - 'Anton'
1970 Commando - 'Bruno'
1967 T120R - 'Caesar'
1972 Commando - 'Big Red'
I had to ring in on this one.
First off, I have purchased two Indian tanks, both fit well however I did find rust inside so I used roofing nails and acetone to clean them then lined with Caswel. I’ve also used Por 15 tank liner kit
Second. My fiberglass tanks all get the Caswel treatment. Same deal clean with acetone
Third. Our all knowing liberal government always screws up everything they touch including our fuel supply. The corn fuel looses it goodness after thirty days but will continue to reek havoc on fiberglass and rubber parts. Lessons learned I never keep fuel in my bikes preferring to drain it for other purposes like killing weeds. It’s really good as a weed killer even at five bucks a gallon is cheaper then Round Up. Tip if your use it for weed killer don’t use a red can, your do good neighbor might get her panties in a bunch because your polluting the ground water, which isn’t really a problem because corn gas evaporates so quickly.
Finally in my classic cars it is not practical to drain the moonshine so I use STA-BILL
1 member likes this: Gary E
Yes it would be paradise on Earth without the Liberals
thankfully ,
Trump as a candidate , promised the continuance of corn subsidy in 2016
and corn and soybean subsidies increased , after his election and during his tenure .
" Swamp cleaning " did not include ... agriculture sbsidies that increased to 14 billion in 2017 .
and again in each year after
... agriculture subsidies help claim votes in farm states where farm animals outnumber people
and where agricultural subsidies help to make up for Donald's failed foreign trade War pricing
The majority of payments in 2020 went to just eight states –
Illinois, Iowa, Kansas, Minnesota, Nebraska, North Dakota, South Dakota and Texas.
Farmers in those states received more than $41 billion, ... 51 percent of the total.
... to be clear , good old fashioned Crony Capitalism , puts corn in your gasoline .
and Crony Capitalism rocks .
2 members like this: Gary E, Gordon Gray
Start lobbying for assistance in aluminium tank making rather
than crap fuel eh?
If someone would bang out a Hornet alloy tank with badge indents I would be first on the list
Crap fuel, geez where do we start. It’s the cause of all things crappy
That and with the correct caps. I noticed with Holtworks, they sell the correct cap for the later spitfires/firebirds etc (flip cap) but don’t give it as an option for fitting into one of their tanks.
Ask the question!
As all Holtworks tanks are made by Tony in his workshop in Essex, alterations to details are easy to accommodate.
The badge indents may incur extra cost as tooling will need to be made
GM500 sprint bike "Deofol"
Rickman Jawa 500 "Llareggub"
Kawasaki Ninja H2 "Fujin"
LIKE RELIGION, YOU SHOULD KEEP YOUR POLITICAL PREJUDICES AND POLITICS TO YOUR SELF THIS IS NOT THE PLACE FOR THEM.
The Devil is in the details.
2001 Kawasaki W650
Ken, history is history.
If you want to know what's happening, or what's going wrong today, you need to know what was done yesterday.
We correct problems with our motorcycles every day because we now know WHY past bad decisions made those problems happen.
History is perspective.
"Fencerow to fencerow, boys..."
2 members like this: grumps65, Gordon Gray
I agree, about political statements but realty it has affected not only what is put into our fuel, but also limits our ability’s to drill for it and driving up the cost. Fuel is the essential product that moves our hobby. So much like an electric or mechanical failure one must go to the expose the source of the problem! If discussion about the fuel issues and the source of how we got here cannot be discussed we are failures. After all open discussions on the demise of the British motorcycle industry are published here, why should the foundation of who is responsible for what happened to creat this crap we fuel up with be fair game.
The Go Green philosophy comes at a huge price, one of those prices is the fuel we must buy ruins certain components on our beloved machines, and the so called contribution to clean air is questionable, and factually documented these additives poison the ground water. You all know it, you all know whose responsible for it and are very aware of the failure rate these individuals have in decision making. Top down just look around.
We bitch a lot here on how messed up EBay has gotten, the quality and price of reproduction parts, the pre conceived opinions of the Indian motorcycle tanks, and on and on.
Let blame be placed on the source of our fuel. Motorcycles are dangerous, and crap fuel enhances those dangers.
Let's do be clear... Environmental justifications aside, crap fuel is here to utilize the glut of corn this country produces. Ever since Earl "loose shoes" Butz took us off the sugar standard and put us on the corn standard. To eliminate the "socialist" practice of farm subsidies, with promises to export all America could grow. Didn't work, so now corn is over-produced, and is put into everydamnthing, including fuel. Damage done is hard to undo. Even Butz, probably realizing the monster he'd created for the benefit of business and industry, warned of the difficulties of dismounting the tiger once you ride it.
Can't imagine anybody would ever consider Butz a Greenie?
it is the conservatives who are promoting the use of ethanol to garner the votes in the red states not the democrats.
2001 Kawasaki W650
When you get excited, it looks like your right hand starts working again. It's a miracle! thumbsup
Starting today, customers will be requred to unload the semis at the back of Wal-Mart, in addition to their self-checkout duties.
Alaska doesn't grow very much corn.
I didn't mention Alaska but most of the states that grow corn are decidedly red. This is why I said that politics do not belong here.
2001 Kawasaki W650
Ken is one of the members I follow. You musta missed where someone explained to him the world wouldn’t come to an end if he didn’t use caps……looks like he was listening.
Now he just needs to get rid of that apology.
Gordon Gray in NC, USA........"STOP blaming the bike!!!!”
[quote=Richard PhillipsThe corn fuel looses it goodness after thirty days but will continue to reek havoc on fiberglass and rubber parts. Lessons learned I never keep fuel in my bikes preferring to drain it for other purposes like killing weeds. It’s really good as a weed killer even at five bucks a gallon is cheaper then Round Up. Tip if your use it for weed killer don’t use a red can, your do good neighbor might get her panties in a bunch because your polluting the ground water, which isn’t really a problem because corn gas evaporates so quickly.
Finally in my classic cars it is not practical to drain the moonshine so I use STA-BILL[/quote]
Ethanol fuel like E5 or E10 (as labelled in the UK/Europe I'm unsure how the USA labels these fuels) actually keeps a higher octane for longer when stored than non-ethanol fuels, As Ethanol is very high octane it means they add less of the higher octane components into regular gasoline. These tend to be small molecules with very low boiling points and vapour pressures such as butane or methyl butane ect. Ethanol has a higher boiling point and vapour pressure than these (due to the hydrogen bonding of the Hydroxy functional group) this means that the ethanol sticks around longer when stored meaning the gasoline you have left after storage is higher octane.
The issues with ethanol fuel’s are yes it will eat through fiberglass and older rubber/plastic parts, Personally any rubber or plastic parts that aren’t ethanol fuel compatible should be replaced due to age as much as ethanol fuels have been around for 30+ years and I want to replace seals and fuel lines that are this old regardless of ethanol compatibility. Fiberglass tanks do need replacing or very well lining, but this is the cost of our hobby.
They can also pick up water which can in extreme cases cause corrosion and a water ethanol mix to come out of solution at the bottom of the tank, But this is in extreme cases, unless you live in an extremely humid place or leave your bike stood for 12+ months with fuel in it its unlikely to cause a problem.
1971 BSA A65T
1968 BSA B44
1 member likes this: BrizzoBrit
The Bad Gas excuse has always puzzled me. My lawnmowers ( both 4 strokes) sit all winter with corn gas in them. Come spring they start right up. 4 months?
Going bad in 30 days just doesn’t sound right. How long does it sit after being refined and delivered to the gas station? Realistically if it takes a couple of weeks….it’s going to go bad in another couple of weeks?
I know some of my bikes have gone longer than 30 days with corn gas left in them….I’d give up the hobby if I had to drain a tank after every use.
Not a corn gas fan…….most of the corn grown around here is used as deer feed and we all know how important that is.
PS…..I’m not saying gas won’t go bad….I’ve cleaned my share of carbs over the years. Just that 30 days doesn’t sound right.
1 member likes this: Noe
Page 2 of 3 1 2 3
