7 members (desco, Rich B, NickL, Tom A65LR, Steve Erickson, Lannis, R Moulding),
13
guests, and
31
robots. |
Key:
Admin,
Global Mod,
Mod
Topics76,577
Posts776,831
Members12,218
Most Online204 Jul 10th, 2022
Posts: 336 Likes: 1
Posts: 336 Likes: 1 |
What is the diameter of the hole behind the mixture screw in a P300 930 AMAL carb? Thank you in advance.
Posts: 143 Likes: 30
50+ years experience
Posts: 143 Likes: 30 |
Hi mrcarb, the #78 pilot jet drill bit is .016", so I would guess the hole would be pretty close to that. Hope this helps. -Dave
Posts: 8,351 Likes: 989
Posts: 8,351 Likes: 989 |
What is the diameter of the hole behind the mixture screw in a P300 930 Amal carb? Do the following two photographs answer your question? ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/17204/filename/Carburetor01.jpg) ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/17205/filename/Carburetor02.jpg)
The Bonneville Shop |
Posts: 6,267 Likes: 250
Posts: 6,267 Likes: 250 |
magneto, that cutaway carb is missing the pressed-in bush in the idle air passage, correct? i dont know what they look like
magneto, that cutaway carb is missing the pressed-in bush in the idle air passage, correct? i dont know what they look like Are you referring to the plug between the front of the carburetor and the idle jet (first photograph), or the brass plug that seals the passage after drilling the two small holes (second photograph)? Or, something else? ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/17209/filename/Carburetor03.jpg) ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/17210/filename/Carburetor04.jpg)
Posts: 3,845 Likes: 270
Posts: 3,845 Likes: 270 |
Posts: 6,084 Likes: 267
Posts: 6,084 Likes: 267 |
MMs pic is the 2 stroke 68 set up with the PJ in the FB roof. Interesting to see the generous passages that the mung lives in.
Maybe it's too obvious to mention, but I'll mention it anyway. Concentrics came in left and right-hand versions, with the two internal passages reversed between the two. ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/17212/filename/Carburetor05.jpg)
