Topics76,525
Posts783,968
Members12,386
Most Online204 Jul 10th, 2022
Posts: 44 Likes: 2
Posts: 44 Likes: 2 |
Hello,
I have a 1970 Triumph Bonneville. The stock 1970 head needs to get sent off or have someone install new valve seats in it. While I figure that out I have a 1964 stamped head which is good to go that I would like to install.
Will the stock 1970 pushrod tubes work? As I understand they may be a bit too long. If the stock pushrod tubes wont work can some point me in the right direction of which ones will work?
Thank you in advance for your response.
1960 - BSA Gold Star 1966 - Triumph T120TT 1970 - Triumph T120 1975 - Norton 850 Electric Start
Posts: 1,654 Likes: 35
Posts: 1,654 Likes: 35 |
No. You will need 68 on back tubes and tappet guide blocks. You need both. Check push rod length. The early head has a much shallower PRT indent than the 69-70 head. FYI A 71-72 head will work with your current prt’s and blocks. Their easy to find.
Who are the Brain Police?
68 B44 Victor 60 MGA 56 Chevy
Bob M.
Posts: 3,811 Likes: 80
Posts: 3,811 Likes: 80 |
Posts: 863 Likes: 99
Posts: 863 Likes: 99 |
The 71/72 will work, but looks silly with the dowels poking out. It is possible to machine the early head for a deeper indent, but it is at an angle, not one for the faint hearted. Also someone, somewhere, will curse you down the line.
kevin |
Posts: 409 Likes: 18
Posts: 409 Likes: 18 |
I had a real PIA trying to put a 71/72 head on my 68 bonnie. I could not get the 72 rocker boxes on over the inner head bolts (motor in frame) and didn't want to have to unbolt the motor any time I wanted to pull the rocker boxes. So I pulled the roll pins and went back to 68 boxes only to find the indents in the head under the head bolts were deep enough to have a gap between the early boxes and the head, this connection is imperative as the 68 head bolts clamp the box to the head as a unit to affect proper torque value and clamping ability. So after a bodge with thinning down washers and three bond I didn't even start it up, still sits in my shop looking pretty with a boogered head fitment. If you're lucky enough to find a 72 head with no indentations it would work with early boxes.
'68 Bonnie, '70 TR6r '74 CL360 trail 70's and minitrails
Posts: 6,612 Likes: 331
Posts: 6,612 Likes: 331 |
i mix and match al that stuff. i have a 1973 9 and 1/2-bolt head with early boxes on it right now.
how were you planning on adapting the later head steady to your 68?
Posts: 5,601 Likes: 223
Posts: 5,601 Likes: 223 |
Or use adjustable pushrod tubes
kevin |
Of course! It could be done by machining alloy tubes, but in no way reversible!
i use ^^^daves adjustable tubes. they work fine.
Posts: 44 Likes: 2
Where does one source these adjustable push rod tubes from?
DMadigan
See 4 posts above here.
Posts: 2,406 Likes: 450
Posts: 2,406 Likes: 450 |
I had a real PIA trying to put a 71/72 head on my 68 bonnie. I could not get the 72 rocker boxes on over the inner head bolts (motor in frame) and didn't want to have to unbolt the motor any time I wanted to pull the rocker boxes. So I pulled the roll pins and went back to 68 boxes only to find the indents in the head under the head bolts were deep enough to have a gap between the early boxes and the head, this connection is imperative as the 68 head bolts clamp the box to the head as a unit to affect proper torque value and clamping ability. So after a bodge with thinning down washers and three bond I didn't even start it up, still sits in my shop looking pretty with a boogered head fitment. If you're lucky enough to find a 72 head with no indentations it would work with early boxes. my old '70 had a later head and rocker boxes, just used the later two part fixings with hex's on on the inside and short bolts for the covers. It was tight getting the covers on and off but was ok. Fabricated a head steady to suit. Dave Madigan does adjustable pushrod tubes if needed.
Posts: 44 Likes: 2
DMadigan, sent you an email.
The 71-72 head works with a 69-70 motor with the eailier rocker boxes just fine using the earlier rocker box gaskets. Pull the locator pins. The 71-72 head will not work with a 68 or earlier motor unless you also change out the tappet guide blocks and PRT tubes. I’ve done this at least 8 times with complete success.
Bob M.
Or Dave's adjustable PRT's?
Posts: 44 Likes: 2
I ended up checking in with a friend on this issue and he referred me to MAP. I purchased a set of their alloy machineable pushrod tubes, they arrived cross country two days after I ordered them. Installed them on the bike, took my measurements and turned them down for a perfect fit.
I am sure an adjustable tube would be better for exact fitment, but this was a one click purchase solution that does not look completely out of the ordinary.
