Cape Carteret, NC
kevin 71
Lannis 70
quinten 61
Lannis 23
MikeG 22
Boardtrackracer, Glen, Dave100, Scott Meredith, JOB
12,219 Registered Users
4 members (L.A.kevin, Carl, Stuart Kirk, kevin), 8 guests, and 22 robots.
Topics76,578
Posts776,841
Members12,218
Most Online204
Jul 10th, 2022
Hello.. and thanks in advance for any advice anyone can give me
My regulator went bad, and I fried a couple batteries before I realized what was going on. I disconnected the regulator and swapped out the rectifier for a Tympanium single phase rectifier/regulator. Initially everything tested out ok... The voltage was around 14.5 volts when i rev'ed the engine. So, I figured everything was ok.
I drove it for a few days, when it suddenly started running rough. I tested the voltage, and it was running up over 16 volts. At the time I assumed I didn't connect the wires right and one was loose. I decided to strip the connecters off... and twist the wires together and solder them together. Thinking that would provide the best connection.
The connections on the wires seemed solid after I was done, but when I retested the bike... The voltage was jumping up over 16 volts. So, I'm wondering if the new rectifier/regulator might be bad.
Can someone tell me if there's a way to test if it's good or bad?
Although unusual, a bad connection can cause the regulator to fail.
If the regulator is connected well to the alternator and to the battery,
you should be able to measure around 14.5v dc at the battery when
the bike is revved to around 3k. If it is substantially more then the
regulator is not doing it's job.
What type of meter are you using to measure the voltage? I ask
because some digital meters may flicker around when presented
with a relatively 'raw' supply. Normally the battery will smooth out
the supply but not always. Tympanium units i have seen over the
years have a single scr type regulator so may present a rougher
waveform than other types which tend to use 2 scr's in inverse
parallel.
Measure with an analogue type instrument to make sure.
Thanks for the reply
I'm using a digital meter... When I initially installed the rectifier/regulator, the voltage tested out around 14.5 volts when i rev'ed up the engine, and iI didn't see the volt meter spike or jump higher than that. The battery charge was 12.6 volts. And at the time I thought the problem had been fixed. After I retested the battery voltage this time, the voltage had dropped to 11.6. Which is why I decided I hadn't fixed it.
To retest the voltage after I soldered the wires together, I bought some alligator clips for my meter, to attached to the battery leads. I figured they'd be a better way to monitor the voltage verses just holding the probes against them. The voltage was bouncing around, but the voltage hit 19+ volts at one point. I went ahead and tossed my battery on a trickle charger last night, and the trickle charger said it was charged. Although I haven't tested the battery with my meter yet. I'm going to check the connection on the wires tomorrow to double check they haven't come loose.
I saw on another thread; someone was asking how to test their rectifier (I think it was for the Lucas rectifier). The replies said connect the negative meter lead to what would have been the center tap, and the positive meter lead to the wires going to the stator. And the reading for a functioning rectifier should be 400 ohms... Do you know if this would test out for a single phase?
Thanks for the advice... I appreciate it
I’d try another reg/rec.
These are cheap-ish and work well for me.
https://www.ebay.co.uk/itm/20378320...r=&widget_ver=artemis&media=COPY
if you are using a cheap digital instrument
https://www.bol.com/nl/nl/p/profess...gdmjtJ8dl63TQNhOKiLGN8lcBSIaAkXcEALw_wcB
the voltage reading goes up when the 9V internal batterij goes flat
how do I know, now using a fluke 179
Sounds like you just got a bad voltage regulator .
You hooked it up correctly and it just crapped out early .
it was Dead Before You soldered it back on .
was it sold with a warranty . ?
I’ve had good and bad luck with Tymps. Finally went to a Podtronics unit.
Who are the Brain Police?
B44 Victor
60 MGA
56 Chevy
Bob M.
I'd like to thank everyone for their reply
Although I'm still wondering... Is there's a way I can test the rectifier/regulator to verify it's bad? I bought it from a local garage, and I'd like to make sure it's bad before i take it out of my bike and take it back to them.
Thanks!
there are 2 AC input leads and 2 DC output leads. put your meter on a scale that reads diodes. most meters have a special function position to do that. a "diode number" is something like 400 -800 ohms)
place the meter + lead on one AC lead and other meter lead on one DC lead.... you should get either "yes" or "no" (400 or infinity). reverse the leads and you should get the other reading. repeat with meter + lead on the other DC lead
then put the meter lead on the other AC input lead and repeat the above
no set under test should read continuity in both directions, and no set should read infinity in both directions. continuity with a higher reading than other pairs is probably bad
a bad ground connection can make the regulator over volt
Thanks!
I think the test you ran is sufficient. There's no way you should be getting 16 volts out of that unit, and I can't see any other cause for that besides a faulty regulator.
Originally Posted by Mitch
...a bad ground connection can make the regulator over volt
This is true only for zener diodes, which are connected in parallel with the rectifier. A disconnected zener on either side will result in no voltage regulation.
nope... its true for any regulator... even one that gets its ground through it's case. resistance in the ground connection means a higher voltage must be applied to overcome the extra resistance. the regulator is not accurately seeing the battery/system voltage. that drives the system voltage up. same is true of extra resistance in the main power lead but it is usually the ground side that has the problem... especially with positive ground where the frame is anodic to the rest of the system. many generator systems have a dedicated wire from the generator to the regulator for that purpose.. it carries no load, it only keeps the potential between the two at the same value
1 member likes this: NickL
Ok, I learned something today; thank you Mitch.
Now if the regulator responds to resistance, does this not imply that a bad battery could also cause an abnormally high charge voltage?
yes... I have seen that happen
