Hi scrap, I only use Barnett cables. They have swaged steel ends, not soldered. I’ve used various brands including Venhill feather lite. Barnett is lined with some sort of plastic. Teflon? Anyway trust me on this. Lube new cable with motor oil!! Like shop
manual shows. Hang cable. Poke hole in baggie & tape it to cable. Overnight will drip out bottom.
Barnett is more costly worth every penny. Shop around, price varies wildly for exact same cable. Last one I found Vintage Triumph Supply was best price. So shop around, that was a year ago.
Again motor oil. Oiling reduces friction by about 35-50%. I oil once a year, about 4-5k miles. This will reduce pull a margin over Venhill featherlite.
Start with Barnett cable.
Springs are all the place with strength. True 750 springs pull very hard. Barnett springs pull as hard. Avoid them.
Try to get 650 springs.
You can tell the tension by measuring the spring wire diameter # of coils & overall length.
If you do not have digital vernier calipers you must purchase some. For this use $20 ones from Harbor Freight or eBay are good enough.
We’ll get into more details later.
Start with cable.
Don’t buy any clutch parts other than cable yet. We need to do tear down first. That will show next steps if cable doesn’t correct problems. I expect cable will not solve all problems, but you must start with perfect cable.
