Yes, tiger the fitment of taper roller bearing kits to a Triumph changes the distance between the top and bottom yokes. It will present itself at the top of the headlamp ears, as the bottom is fixed. typically a thick "O" ring will fill the gap. Most bike I see fitted with tapered steering neck bearings the owner ignored the gap and it is left as is.
john
