Upgrade your membership to Premium Membership or Gold Membership or even Benefactor
10% Off Girling at The Bonneville Shop 2/3-2/9/23
by The Bonneville Shop - 02/03/23 6:14 pm
Benefactor ✅
by Morgan aka admin - 02/09/23 11:15 am
by Morgan aka admin - 02/08/23 12:00 pm
Buy BritBike staff a coffee ☕️ or pint 🍺
by Morgan aka admin - 01/15/23 9:29 am
Zimm
Zimm
The land of pleasant living
Lannis 90
DavidP 84
kevin 56
Kev. 32
DavidP 26
Lannis 26
Igloo, patrickblue, j-bud, Uneasy Rider, Mally
12,395 Registered Users
Topics76,568
Posts784,692
Members12,395
Most Online204
Jul 10th, 2022
#884944 07/07/22 1:02 pm
Beach Offline OP
Lost compression on left cylinder of my 66 Atlas. Tore down and found left piston scuffed really bad and right piston mildly scuffed. Left cylinder had scuffed marks. Thinking previous owner may not not have set clearance to .0045". Any thoughts?[Linked Image][Linked Image][Linked Image][Linked Image]
1974 Norton Commando
1966 Lightning
1965 Lightning Rocket
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Norton on eBay
Obviously it has siezed. If it has been rebored you may have egg shaped cylinders What is the clearance now??.
Beach Offline OP
That may be. Haven't measured the bores yet.
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Significant difference between the 2 piston tops, one nice and clean the other carboned up. pre ignition from oil getting past the rings may be the issue not lack of clearance. Any aluminum bonded to the bore can safely be removed using hydrochloric acid, then measure the bore.
The right side piston scratches may be from honing grit or maybe debris from the other piston.
The left one looks like someone persevered after a seizure. That would let oil into the combustion chamber as Mr K said, maybe leading to detonation that chewed the edge off the piston top.
Beach Offline OP
Was on interstate cruising when this happened. Noticed smoke in mirror and pulled over. Guess the main thing is to make sure cylinders are bored correctly this time. Pistons are .040" over now. Figure there is enough metal to run .060 over pistons.
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Crew Chief
Crew Chief
Flat top Commando or dished atlas pistons?
Mag AA unit fail to retard making over advance at low rpm & big throttle?
Magneto timing difference between cylinders?
Coming to the NY rally?
dynodave
http://www.NNENO.org
I like Norton Heavy Twins
http://atlanticgreen.com
Beach Offline OP
[Linked Image]Flat top pistons with 2 base gaskets and spacer. Checked timing on ramps when setting magneto and advance is working fine.
Not going to make the rally, wife has had medical issues we're dealing with. Looks like it will be a good one.
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Curious that a lot of the scuffing seems to be on the sides of the pistons, not on the thrust faces.
Makes you wonder if the pistons were cam-ground ???
That does seem to be a big difference in appearance between pistons ..
Twin carbs ?
Beach Offline OP
Yes twin carbs.
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Crew Chief
Crew Chief
Originally Posted by Beach
Yes twin carbs.
curious ? 66 atlas 389-689 or chopped Monobloc?
I've got a 66 also 1189xx not running, but a complete basket case.
dynodave
Beach Offline OP
389-689 Got motor on bench and going to check gaps and timing on mag(just in case), check sealing surfaces on carbs and insulators.
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Beach Offline OP
Gap big at .017(should be .012) but was same on both ramps. Don't think this would cause a lean condition. Next check of timing.
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
If the gap increases, that advances the timing.
Crew Chief
Crew Chief
Yes just checked it out. The moving points (coil power) while closing, could beat a loose stationary points (armature ground) causing them to rotate and open up. not good ! ! !
dynodave
Beach Offline OP
Maybe that's the problem.
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Beach Offline OP
Got motor out and completely apart. It will be correct in a few weeks. Is there an easy way to check the oprv? Want to eliminate all possibilities.
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Crew Chief
Crew Chief
It is more likley 10 or even 20:1 it is the pump is crappy rather than the OPV opening early. I can check them on my oil pump tester rig.. I can shut off the exit and send pump output 100% to the OPV and have a pressure gauge only on that circuit...you can see the response as the regulation starts to kick in...
55-60-65 ?
dynodave
Lost compression on left cylinder of my 66 Atlas. .....left piston scuffed really bad ...... Any thoughts?[Linked Image]
I'm thinking detonation happened first. Detonation can collapse the ring lands which pinches the rings which stops them sealing. Hot gases destroy the lubrication and seizure results. It can happen quick.
Things to check or consider:
Ignition timing variation side to side.
Full advanced ignition timing.
Carb synchronization.
Fuel blockage.
Jetting.
Fuel quality.
Compression ratio.
Wouldn't a bigger points gap retard the spark.
Quite considerably, for 0.017 "
Which can also make a motor run hot
The fire doesn't even get started until it should be *half over ...
*approx, or a bit less ...
**assuming it wasn't set/timed like that.
No, a bigger points gap advances the spark.
Beach Offline OP
Figured out what happened. The original pistons when I purchased were hepolite with groove in side for oiling(bad idea). Replaced with JCC pistons .040 over clearance at .0045. Last year I pulled my points to check for proper mating and clean contacts. Put back in at, I thought .012 gap and timing should have remained the same. Checked gap yesterday and found they were at .017, enough to advance timing and cause detonation and the damage to piston. Don't know how I did it but glad to have found the problem.
Thx for all the helpful feedback.
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
So how would the gap go from 0.012 to 0.017 ?
If the spark had advanced, muchly, you'd have heard it pinking and carrying on ?
And it would be a pig to start, if not downright cranky !
Now if you had accidentally timed it at 0.017 then the dwell would be less and it would/could produce a weak spark.
This can delay the onset of the fire, and engines will run hot from this.
Probably a bit late for a proper post mortem ...
When we accidentally over-advance our ignition, by having too big a points gap, the problem is over-advanced ignition. That is the opposite of “delayed onset of fire.”
The rider doesn’t always hear pinking at road speed.
1 member likes this: Beach
Beach Offline OP
I explained in previous post how the points ended at .017 and it started easy and there was no noticeable noise at highway speed as Triton mentioned.
1966 Lightning
1966 Norton Atlas
1967 Norton Atlas
1948 Panhead
Moderated by  Dave Comeau
