Topics76,796
Posts788,371
Members12,445
Most Online230 Mar 11th, 2023
Posts: 1,129 Likes: 96
Posts: 1,129 Likes: 96 |
Bill 1974 Norton Commando 1966 Lightning 1965 Lightning Rocket 1966 Norton Atlas 1967 Norton Atlas 1948 Panhead
Posts: 304 Likes: 8
Posts: 304 Likes: 8 |
Obviously it has siezed. If it has been rebored you may have egg shaped cylinders What is the clearance now??.
That may be. Haven't measured the bores yet.
Posts: 11,815 Likes: 317
Posts: 11,815 Likes: 317 |
Significant difference between the 2 piston tops, one nice and clean the other carboned up. pre ignition from oil getting past the rings may be the issue not lack of clearance. Any aluminum bonded to the bore can safely be removed using hydrochloric acid, then measure the bore.
Posts: 9,327 Likes: 244
Posts: 9,327 Likes: 244 |
The right side piston scratches may be from honing grit or maybe debris from the other piston.
The left one looks like someone persevered after a seizure. That would let oil into the combustion chamber as Mr K said, maybe leading to detonation that chewed the edge off the piston top.
Was on interstate cruising when this happened. Noticed smoke in mirror and pulled over. Guess the main thing is to make sure cylinders are bored correctly this time. Pistons are .040" over now. Figure there is enough metal to run .060 over pistons.
Posts: 1,787 Likes: 43
Crew Chief
Crew Chief
Posts: 1,787 Likes: 43 |
Flat top Commando or dished atlas pistons? Mag AA unit fail to retard making over advance at low rpm & big throttle? Magneto timing difference between cylinders? Coming to the NY rally?
![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/16768/filename/20220705_202106.jpg) Flat top pistons with 2 base gaskets and spacer. Checked timing on ramps when setting magneto and advance is working fine. Not going to make the rally, wife has had medical issues we're dealing with. Looks like it will be a good one.
Posts: 5,119 Likes: 119
Posts: 5,119 Likes: 119 |
Curious that a lot of the scuffing seems to be on the sides of the pistons, not on the thrust faces. Makes you wonder if the pistons were cam-ground ???
That does seem to be a big difference in appearance between pistons .. Twin carbs ?
Crew Chief
Crew Chief
curious ? 66 atlas 389-689 or chopped Monobloc? I've got a 66 also 1189xx not running, but a complete basket case.
389-689 Got motor on bench and going to check gaps and timing on mag(just in case), check sealing surfaces on carbs and insulators.
Gap big at .017(should be .012) but was same on both ramps. Don't think this would cause a lean condition. Next check of timing.
Gap big at .017(should be .012) but was same on both ramps. Don't think this would cause a lean condition. Next check of timing. If the gap increases, that advances the timing.
Crew Chief
Crew Chief
Yes just checked it out. The moving points (coil power) while closing, could beat a loose stationary points (armature ground) causing them to rotate and open up. not good ! ! !
Maybe that's the problem.
Got motor out and completely apart. It will be correct in a few weeks. Is there an easy way to check the oprv? Want to eliminate all possibilities.
Crew Chief
Crew Chief
It is more likley 10 or even 20:1 it is the pump is crappy rather than the OPV opening early. I can check them on my oil pump tester rig.. I can shut off the exit and send pump output 100% to the OPV and have a pressure gauge only on that circuit...you can see the response as the regulation starts to kick in... 55-60-65 ?
Posts: 1,488 Likes: 520
Posts: 1,488 Likes: 520 |
Lost compression on left cylinder of my 66 Atlas. .....left piston scuffed really bad ...... Any thoughts? ![[Linked Image]](https://www.britbike.com/forums/ubbthreads.php/ubb/download/Number/16767/filename/20220705_202255.jpg) I'm thinking detonation happened first. Detonation can collapse the ring lands which pinches the rings which stops them sealing. Hot gases destroy the lubrication and seizure results. It can happen quick. Things to check or consider: Ignition timing variation side to side. Full advanced ignition timing. Carb synchronization. Fuel blockage. Jetting. Fuel quality. Compression ratio.
Wouldn't a bigger points gap retard the spark. Quite considerably, for 0.017 "
Which can also make a motor run hot The fire doesn't even get started until it should be *half over ...
*approx, or a bit less ... **assuming it wasn't set/timed like that.
*approx, or a bit less ... **assuming it wasn't set/timed like that. No, a bigger points gap advances the spark.
Figured out what happened. The original pistons when I purchased were hepolite with groove in side for oiling(bad idea). Replaced with JCC pistons .040 over clearance at .0045. Last year I pulled my points to check for proper mating and clean contacts. Put back in at, I thought .012 gap and timing should have remained the same. Checked gap yesterday and found they were at .017, enough to advance timing and cause detonation and the damage to piston. Don't know how I did it but glad to have found the problem. Thx for all the helpful feedback.
So how would the gap go from 0.012 to 0.017 ? If the spark had advanced, muchly, you'd have heard it pinking and carrying on ? And it would be a pig to start, if not downright cranky ! Now if you had accidentally timed it at 0.017 then the dwell would be less and it would/could produce a weak spark. This can delay the onset of the fire, and engines will run hot from this.
Probably a bit late for a proper post mortem ...
Probably a bit late for a proper post mortem ... When we accidentally over-advance our ignition, by having too big a points gap, the problem is over-advanced ignition. That is the opposite of “delayed onset of fire.” The rider doesn’t always hear pinking at road speed.
Beach |
Probably a bit late for a proper post mortem ... I explained in previous post how the points ended at .017 and it started easy and there was no noticeable noise at highway speed as Triton mentioned.
